Hi everyone,
i’m trying to decode a great radiator thermostat actuator in lorawan.
this one get lot of information has it control a motor. nevertheless i get the JS decoder on the fabricant website.
This one not compile in the codec section of the Aapplication Server .
i try to downgrade the JS code to ES5 with babeljs.io . a web compiler…
It replace let
by var
and some function … but it still blocking on the Object.assign(…) method.
some one could help me?
let see the JS decoder: I have replaced the function name to meet the AS- codec requirements
let deviceData = {};
function Decode(fport,bytes) {
const toBool = value => value == '1';
let decbin = (number) => {
if (number < 0) {
number = 0xFFFFFFFF + number + 1
return parseInt(number, 10).toString(2)
const handleKeepAliveData = (byteArray) => {
let tmp = ("0" + byteArray[6].toString(16)).substr(-2);
let motorRange1 = tmp[1];
let motorRange2 = ("0" + byteArray[5].toString(16)).substr(-2);
let motorRange = parseInt(`0x${motorRange1}${motorRange2}`, 16);
let motorPos2 = ("0" + byteArray[4].toString(16)).substr(-2);
let motorPos1 = tmp[0];
let motorPosition = parseInt(`0x${motorPos1}${motorPos2}`, 16);
let batteryTmp = ("0" + byteArray[7].toString(16)).substr(-2)[0];
let batteryVoltageCalculated = 2 + parseInt(`0x${batteryTmp}`, 16) * 0.1;
let byteBin = decbin(byteArray[7]);
let openWindow = byteBin.substr(4, 1);
let childLockBin = decbin(byteArray[8]);
let childLock = childLockBin.charAt(0);
let highMotorConsumption = byteBin.substr(-2, 1);
let lowMotorConsumption = byteBin.substr(-3, 1);
let brokenSensor = byteBin.substr(-4, 1);
let keepaliveData = {
reason: byteArray[0],
targetTemperature: byteArray[1],
sensorTemperature: (byteArray[2] * 165) / 256 - 40,
relativeHumidity: (byteArray[3] * 100) / 256,
motorRange: motorRange,
motorPosition: motorPosition,
batteryVoltage: batteryVoltageCalculated,
openWindow: toBool(openWindow),
childLock: toBool(childLock),
highMotorConsumption: toBool(highMotorConsumption),
lowMotorConsumption: toBool(lowMotorConsumption),
brokenSensor: toBool(brokenSensor),
rssi: rssi
Object.assign(deviceData, { ...deviceData }, { ...keepaliveData })
if (bytes) {
let byteArray = bytes.match(/.{1,2}/g).map(byte => { return parseInt(byte, 16) })
if (byteArray[0] == 1) {
// its a keeapalive
handleKeepAliveData(byteArray);
} else {
let resultToPass = {};
let data = bytes.slice(0, -18);
let commands = data.match(/.{1,2}/g);
// console.log(data)
commands.map((command, i) => {
switch (command) {
case '15':
let data = { temperatureRangeSettings: { min: parseInt(commands[i + 1], 16), max: parseInt(commands[i + 2], 16) } };
Object.assign(resultToPass, { ...resultToPass }, { ...data });
break;
case '14':
let data = { childLock: toBool(parseInt(commands[i + 1], 16)) };
break;
case '12':
let data = { keepAliveTime: parseInt(commands[i + 1], 16) };
break;
case '13':
let enabled = toBool(parseInt(commands[i + 1], 16));
let duration = parseInt(commands[i + 2], 16) * 5;
let tmp = ("0" + commands[i + 4].toString(16)).substr(-2);
let motorPos2 = ("0" + commands[i + 3].toString(16)).substr(-2);
let delta = Number(tmp[1]);
let data = { openWindowParams: { enabled: enabled, duration: duration, motorPosition: motorPosition, delta: delta } };
break;
case '18':
let data = { operationalMode: (commands[i + 1]).toString() };
break;
case '16':
let data = { internalAlgoParams: {period: parseInt(commands[i + 1], 16), pFirstLast: parseInt(commands[i + 2], 16), pNext: parseInt(commands[i + 3], 16)} };
break;
case '17':
let data = { internalAlgoTdiffParams: {warm: parseInt(commands[i + 1], 16), cold: parseInt(commands[i + 2], 16)} };
break;
case '1b':
let data = { uplinkType: commands[i + 1] };
break;
case '19':
let commandResponse = parseInt(commands[i + 1], 16);
let periodInMinutes = (commandResponse * 5) / 60;
let data = { joinRetryPeriod: periodInMinutes };
break;
Object.assign(deviceData, { ...deviceData }, { ...resultToPass });
// get only keepalive from device response
let keepaliveData = bytes.slice(-18);
let dataToPass = keepaliveData.match(/.{1,2}/g).map(byte => { return parseInt(byte, 16) });
handleKeepAliveData(dataToPass);
return deviceData;
