JavaScript Decrypt Code Errors
Hi Everyone, I want to run JavaScript Decrypt Code on Raspberry Pi but my code shows these errors, if anyone have any idea please let me know. Same code is successfully running on Visual Studio Code but in Rpi not. Thanks in advance.
module.js:340
throw err;
Error: Cannot find module 'node-aes-cmac’
at Function.Module._resolveFilename (module.js:338:15)
at Function.Module._load (module.js:280:25)
at Module.require (module.js:364:17)
at require (module.js:380:17)
at Object. (/home/pi/naveed/LoraPD3/LoraTest/mic.js:27:15)
at Module._compile (module.js:456:26)
at Object.Module._extensions…js (module.js:474:10)
at Module.load (module.js:356:32)
at Function.Module._load (module.js:312:12)
your code using module, which isn’t found on your platform.
Do a:
npm install node-aes-cmac
You can also include it into your packages.json
Mk…
