Moreover, i found a shell script inside the gateway (/opt/LoraServerIO/bin/Lora_pkt_fwd), that, once run:
INFO: Little endian host
INFO: found global configuration file global_conf.json, parsing it
INFO: global_conf.json does contain a JSON object named SX1301_conf, parsing SX1301 parameters
INFO: lorawan_public 1, clksrc 1
INFO: no configuration for LBT
INFO: antenna_gain 0 dBi
INFO: Configuring TX LUT with 16 indexes
INFO: radio 0 enabled (type SX1257), center frequency 867500000, RSSI offset -166.000000, tx enabled 1, tx_notch_freq 129000
INFO: radio 1 enabled (type SX1257), center frequency 868500000, RSSI offset -166.000000, tx enabled 0, tx_notch_freq 0
INFO: Lora multi-SF channel 0> radio 0, IF -137500 Hz, 125 kHz bw, SF 7 to 12
INFO: Lora multi-SF channel 1> radio 0, IF 202500 Hz, 125 kHz bw, SF 7 to 12
INFO: Lora multi-SF channel 2> radio 1, IF -400000 Hz, 125 kHz bw, SF 7 to 12
INFO: Lora multi-SF channel 3 disabled
INFO: Lora multi-SF channel 4 disabled
INFO: Lora multi-SF channel 5 disabled
INFO: Lora multi-SF channel 6 disabled
INFO: Lora multi-SF channel 7 disabled
INFO: Lora standard channel 8 disabled
INFO: FSK channel 8 disabled
INFO: global_conf.json does contain a JSON object named gateway_conf, parsing gateway parameters
INFO: gateway MAC address is configured to XXXXXXXXXXX
INFO: server hostname or IP address is configured to “192.168.23.83”
INFO: upstream port is configured to “1700”
INFO: downstream port is configured to “1700”
INFO: downstream keep-alive interval is configured to 10 seconds
INFO: statistics display interval is configured to 30 seconds
INFO: upstream PUSH_DATA time-out is configured to 100 ms
INFO: packets received with a valid CRC will be forwarded
INFO: packets received with a CRC error will NOT be forwarded
INFO: packets received with no CRC will NOT be forwarded
INFO: GPS serial port path is configured to “/dev/ttyAMA0”
INFO: Reference latitude is configured to 0.000000 deg
INFO: Reference longitude is configured to 0.000000 deg
INFO: Reference altitude is configured to 0 meters
INFO: Auto-quit after 1 non-acknowledged PULL_DATA
WARNING: [main] impossible to open /dev/ttyAMA0 for GPS sync (check permissions)
Library version information: Version: Embit HAL Library Version 2.0SP Build 20180320
INFO: FPGA supported features: [TX filter] [Spectral Scan] [LBT]
INFO: [main] concentrator started, packet can now be received
INFO: Disabling GPS mode for concentrator’s counter…
INFO: host/sx1301 time offset=(1614679118s:782654µs) - drift=-951246658µs
INFO: Enabling GPS mode for concentrator’s counter.
INFO: [down] PULL_ACK received in 0 ms
INFO: [down] PULL_ACK received in 1 ms
INFO: Received pkt from mote: D0036CA9 (fcnt=46037)
JSON up: {“rxpk”:[{“tmst”:14347659,“chan”:2,“rfch”:1,“freq”:868.100000,“stat”:1,“modu”:“LORA”,“datr”:“SF7BW125”,“codr”:“4/5”,“lsnr”:10.0,“rssi”:-73,“size”:23,“data”:“AKlsA9B+1bNwf0QRcAbFGwCOPQRPjio=”}]}**
INFO: [up] PUSH_ACK received in 1 ms
INFO: [down] PULL_RESP received - token[176:60] : )
JSON down: {“txpk”:{“imme”:false,“rfch”:0,“powe”:14,“ant”:0,“brd”:0,“tmst”:19347659,“freq”:868.1,“modu”:“LORA”,“datr”:“SF7BW125”,“codr”:“4/5”,“ipol”:true,“size”:33,“data”:“IORHeE6ORTu0wgQ/cFrfVW1Oa/puFdeIDKmCsG2mdp/5”}}
ERROR: Packet REJECTED, unsupported frequency - 868100000 (min:865000000,max:867000000)
JSON down: {“txpk”:{“imme”:false,“rfch”:0,“powe”:27,“ant”:0,“brd”:0,“tmst”:20347659,“freq”:869.525,“modu”:“LORA”,“datr”:“SF12BW125”,“codr”:“4/5”,“ipol”:true,“size”:33,“data”:“IORHeE6ORTu0wgQ/cFrfVW1Oa/puFdeIDKmCsG2mdp/5”}}
ERROR: Packet REJECTED, unsupported frequency - 869525000 (min:865000000,max:867000000)
JSON up: {“rxpk”:[{“tmst”:26948811,“chan”:2,“rfch”:1,“freq”:868.100000,“stat”:1,“modu”:“LORA”,“datr”:“SF7BW125”,“codr”:“4/5”,“lsnr”:9.2,“rssi”:-69,“size”:23,“data”:“AKlsA9B+1bNwf0QRcAbFGwAiCCqyHbU=”}]}
INFO: [down] PULL_RESP received - token[141:192] : )
JSON down: {“txpk”:{“imme”:false,“rfch”:0,“powe”:14,“ant”:0,“brd”:0,“tmst”:31948811,“freq”:868.1,“modu”:“LORA”,“datr”:“SF7BW125”,“codr”:“4/5”,“ipol”:true,“size”:33,“data”:“IBPB9GnQGUqqlehY0m8uo5lxUxfWelFFKYUclY7gHSmz”}}
JSON down: {“txpk”:{“imme”:false,“rfch”:0,“powe”:27,“ant”:0,“brd”:0,“tmst”:32948811,“freq”:869.525,“modu”:“LORA”,“datr”:“SF12BW125”,“codr”:“4/5”,“ipol”:true,“size”:33,“data”:“IBPB9GnQGUqqlehY0m8uo5lxUxfWelFFKYUclY7gHSmz”}}
2021-03-02 09:59:11 GMT #####
[UPSTREAM] ###
RF packets received by concentrator: 2
CRC_OK: 100.00%, CRC_FAIL: 0.00%, NO_CRC: 0.00%
RF packets forwarded: 2 (46 bytes)
PUSH_DATA datagrams sent: 2 (409 bytes)
PUSH_DATA acknowledged: 100.00%
[DOWNSTREAM] ###
PULL_DATA sent: 3 (100.00% acknowledged)
PULL_RESP(onse) datagrams received: 4 (854 bytes)
RF packets sent to concentrator: 0 (132 bytes)
TX errors: 0
BEACON queued: 0
BEACON sent so far: 0
BEACON rejected: 0
[JIT] ###
SX1301 time (PPS): 32257999
src/jitqueue.c:448:jit_print_queue(): INFO: [jit] queue is empty
[GPS] ###
GPS sync is disabled
END #####
I think the error is self explaining, but i now can’t figure out what and where is wrong with my parameters! This is the network configuration file:
