Here the issue, we are currently testing chirpstack on 3 different devices :
A. VM with ubuntu
B. Raspberry pi with raspberry OS
C. Raspberry pi with ubuntu
On A and C, no issue the activation process is working fine
On B, application key will always stays to 00 00 00 00 …
Joint request is received, then :
error:“join-server returned error: response error, code: Other, description: get device-keys error: object does not exist”
All the solution A,B,C are using the same settings, the same transmitters.
Any taught ?
Best regards
