Join Request Not Received by ChirpStack in Mesh Gateway Setup
Hi everyone,
I’m setting up a network of gateways (connected via a mesh network) using ChirpStack as the LoRaWAN Network Server and ChirpStack Gateway OS.
Relay gateways are based on Raspberry Pi Zero 2W + WM1302, while border gateways use Raspberry Pi 4 + WM1302.
I’m encountering a recurring issue where the join process is unreliable — sensors eventually manage to join, but the Join Request is often not received by ChirpStack at all.
Once the devices are joined, uplink/downlink communication works fine (with RX1 delay set to 5 seconds, for example). However, the initial join is flaky, and it seems that Join Request packets are either lost or not properly forwarded to ChirpStack.
:white_check_mark: What works:
  • End devices eventually join (sometimes after multiple attempts).
  • Uplink/downlink traffic works correctly once the join succeeds.
  • All gateways appear online and connected to ChirpStack (border gateways show up in the classic Gateway Dashboard, relay gateways appear in the Mesh Gateway Dashboard).
:warning: Issues:
  • Join Request packets often don’t appear at all in ChirpStack’s “Live LoRaWAN Frames”, even though the sensors are transmitting them.
  • After several retries, the join typically succeeds.
:mag: Troubleshooting steps taken:
  • Verified that the border gateways are correctly forwarding packets to ChirpStack (via MQTT). When using only the border gateway with direct uplink enabled, the join works reliably.
  • Checked that all gateways and ChirpStack use the same LoRaWAN region and frequency plan (e.g., EU868).
  • Confirmed that the mesh link between gateways is active (same keys, spreading factors, and regions).
  • Ensured NTP is running on the ChirpStack server and the border gateway (to avoid timestamp issues). The mesh gateways are synchronized manually using the “browser time update” feature.
:question:Questions:
  • Could packet loss or timestamp mismatches in the mesh network explain why Join Requests are not processed?
  • Are there known issues with using multiple mesh-connected gateways where only some receive Join Requests but fail to forward them correctly?
  • Is there a recommended method to debug gateway → ChirpStack packet loss, especially for Join Request packets?
I don’t have enough time today to analyze the full logs, but I should be able to do so tomorrow or next week.
Any insights or suggestions would be greatly appreciated. I can share gateway logs or configuration files if needed.
Thanks!
— Thibaud
