I have a gateway sending messages correctly to Lora Gateway Bridge and it forwards messages just fine to Lora Server. However, an error occurs when Lora Server tries to communicate with Lora App Server:
$ journalctl -f -n 100 -u loraserver
log:
Aug 07 12:20:50 SRV-LORA loraserver[16269]: time="2019-08-07T12:20:50-03:00" level=info msg="gateway/mqtt: uplink frame received"
Aug 07 12:20:50 SRV-LORA loraserver[16269]: time="2019-08-07T12:20:50-03:00" level=info msg="packet(s) collected" dev_eui=0002ddf89fc4da5f gw_count=1 gw_ids=c0ee40ffff294303 mtype=JoinRequest
Aug 07 12:20:50 SRV-LORA loraserver[16269]: time="2019-08-07T12:20:50-03:00" level=error msg="processing uplink frame error" data_base64="AIH4AdB+1bNwX9rEn/jdAgC5y08lvqs=" **error="join-request to join-server error: http post error: Post tcp://127.0.0.1:1883: unsupported protocol scheme \"tcp\""**
I understand that a POST request should be requested to a http[s] scheme, but I am a bit confuse here why it is trying to request it to a tcp scheme.
My Lora App Server and Lora Server configuration are mostly the default ones accordingly to loraserver.io guides.
Thank you very much in advance.
