As things stand:
- Two private-network gateways, geographically far apart: Gateway
CF
and GatewaySB
- Two devices, Device
DB
and DeviceB4
. - The two devices have been OTAA JOIN’ing and sending data successfully the past few weeks over gateway
CF
. - At gateway
SB
- we seeJoinRequests
, and noJoinAccepts
- We did not change the devices, only powered-off and powered-on.
Today we are testing out devices DB
and B4
in the geographical area where Gateway SB
is installed:
- We see the LoRaWAN
JoinRequest
frame come in to the GatewaySB
- At
#/organizations/1/gateways/<SB-dev-eui>/frames
- At
JoinRequest
frame come in through the Devices- At
#/organizations/1/applications/1/devices/<DB-dev-eui>/frames
and #/organizations/1/applications/1/devices/<B4-dev-eui>/frames
- At
- We do not see a
JoinAccept
generated by ChirpStack, as we have many times before in the past weeks on gatewayCF
. - We do not see any error in Device Data, this stays clear:
#/organizations/1/applications/1/devices/<B4-dev-eui>/data
We followed https://www.chirpstack.io/project/guides/connect-device/#troubleshooting and disabled frame-counter validation for device DB
(not believing that that is the cause of our issue), and got one error - the “validate dev-nonce error”. Saw this here:
#/organizations/1/applications/1/devices/<DB-dev-eui>/data
So now we are stumped. ChirpStack keeps on receiving JoinRequests
and routing it to the correct device. ChirpStack does not respond, and does not generate errors either.
What can we check next?
