Hi
We are getting this error in AppServer logs in chirpstack
time=“2021-04-03T22:08:47-05:00” level=info msg=“finished streaming call with code Unauthenticated” error=“rpc error: code = Unauthenticated desc = authentication failed: jwt parse error: token is expired by 21h55m26s” grpc.code=Unauthenticated grpc.method=StreamFrameLogs grpc.service=api.DeviceService grpc.start_time=“2021-04-03T22:08:47-05:00” grpc.time_ms=0.223 peer.address="[::1]:54074" span.kind=server system=grpc
time=“2021-04-03T22:08:57-05:00” level=info msg=“backend/joinserver: request received” message_type=JoinReq receiver_id=0000000000000000 sender_id=000000 transaction_id=1349850138
When we try to make join request from our development board with Lora 1272xx module
Some join requests are successfull with Joinaccept response but some are failling with the error above.
We have chirpstack server deployed at VirtualBox and enabled the port forwarding as required for mqtt broker. Tecktelic Gateway is lying nearby to device only configured with gateway bridge and udp packet forwarder.If some more setting need to be performed .
Please suggest.
I have seen the similar topics but did not understand that what i need to perform to resolve the issue.
