This has been solved before but because of the name change to chirpstack the topic links are mostly broken.
I get this error;
“authentication failed: jwt parse error: token contains an invalid number of segments”
While trying to run the example python packet enqueue program.
I have found this explanation;
In order to use the gRPC API methods, you must provide per-RPC credentials. The key for this metadata is authorization , the value Bearer <API TOKEN> (replace with the API TOKEN obtained using the web-interface).
However I don’t know what it means.
I’ve got my end device prototype passing data successfully via a RAK831 based gateway and can see the frames in the web interface. I can enqueue packets and get them to my device using the web interface but now want to move to the next step.
Thanks,
Dennis
