Hi all,
I operate a kerlink wirnet with the LoRa gateway bridge installed directly on the gateway. Statistic data are received every 120s and are forwarded to the MQTT broker
On the Kerlink:
INFO[0734] gateway: received udp packet from gateway addr="127.0.0.1:43080" protocol_version=2 type=PushData
INFO[0734] gateway: stat packet received addr="127.0.0.1:43080" mac=7276ff000b03084d
INFO[0734] backend: publishing packet qos=2 topic=gateway/7276ff000b03084d/stats
INFO[0734] gateway: sending udp packet to gateway addr="127.0.0.1:43080" protocol_version=2 type=PushACK
On the Broker
gateway/7276ff000b03084d/stats {"mac":"7276ff000b03084d","time":"2018-03-19T12:12:32Z","rxPacketsReceived":1,"rxPacketsReceivedOK":0,"txPacketsReceived":0,"txPacketsEmitted":0,"customData":null}
As far as I understood, this is the correct behavior. Now, I want to send a command (AQE=) to my Class-C Comtac Device:
From the Application to the LoRa App Server:
application/1/node/70b3d5fffe297207/tx {
"reference": "actd1238888",
"confirmed": true,
"fPort": 10,
"data": "AQE="
From the LoRa Server dedicated to the gateway:
gateway/7276ff000b03084d/tx {"token":25551,"txInfo":{"mac":"7276ff000b03084d","immediately":true,"frequency":869525000,"power":14,"dataRate":{"modulation":"LORA","spreadFactor":12,"bandwidth":125},"codeRate":"4/5","iPol":null,"board":0,"antenna":0},"phyPayload":"oCsMbgCARAAKKPvrsO19"}
As far as I see, the topic seems to be correct (refer to the stats above), doesn’t it?
Nevertheless, the LoRa Gateway Bridge does not react on this message … there is no log-entry at all on the LoRa Gateway Bridge (log level 5).
Any idea, why the LoRa Gateway Bridge does not react on this topic?
