I’m trying to connect some ifemtocells to my loraserver.
Configuration seems ok, openvpn correctly connects to the server, and everything is working correctly.
The only problem I have is that both the 2 gateways I’m testing are rebooting every 50-60 minutes.
On the /var/log/messages the only information is the one of the reboot itself:
Jul 17 11:51:05 klk-wifc-XXXXXX user.notice shutdown[1292]: shutting down for system reboot
Jul 17 11:51:05 klk-wifc-XXXXXX daemon.info init: Switching to runlevel: 6
But I can’t understand the cause of this.
The only other strange line on the logs I can see, but not near to the reboots, is:
Jul 17 12:01:39 klk-wifc-XXXXXX daemon.info kerosd[804]: Reset bootfail
I just add that the network is still working when this happens, and the only suspect I had was /etc/network/networkmonitoring.conf, but it doesn’t seem to be the cause as even changing the reboot parameters this always happens at around 50-60 minutes of uptime.
Any idea on what to check?
Thanks
