I’m setting up a Kerlink iStation gateway with software version 5.11 to work with Chirpstack. I followed the steps in the Chirpstack page but I have some doubts. Here I mention my observations:
- I enabled Kerlink CPF:
klk_apps_config --activate-cpf
- I edited /etc/lorafwd.toml setting up the following:
[ gateway ]
id = 0x7076ff0055123456
[ gwmp ]
node = “127.0.0.1”
service.uplink = 1700
service.downlink = 1700
- Then installed chirpstack-mqtt-forwarder_4.3.0-r1_klkgw.ipk
- Edited chirpstack-mqtt-forwarder.toml
[logging]
level=“debug”
log_to_syslog=true
[backend]
enabled=“semtech_udp”
[backend.semtech_udp]
bind=“0.0.0.0:1700”
[mqtt]
topic_prefix=“us915_0”
server=“tcp://myserver.mydomain.net:1884”
- Then fighted a while with the Kerlink firewall, ended up disabling it for now.
My doubts so far:
- In the past when using gateway-bridge IPK there was a way for Chirpstack to tell the gateway in which channels to listen, etc. Is this info now flowing thru MQTT with the mqtt-forwarder?
- Do I need to enable anything specific in the Kerlink firewall?
- I noticed it took 20+ minutes until I saw the Gateway as active in Chirpstack. Is that normal? I’m used to see other gateways using gateway-bridge becoming active in seconds.
Thanks,
LeoC.
