I’ve set up mqtt forwarder, but it seems to go into restart loop:
monit[1010]: ‘chirpstack-mqtt-forwarder’ process is not running
monit[1010]: ‘chirpstack-mqtt-forwarder’ trying to restart
monit[1010]: ‘chirpstack-mqtt-forwarder’ start: ‘/bin/bash -c /etc/init.d/chirpstack-mqtt-forwarder start’
chirpstack-mqtt-forwarder[1331]: Starting ChirpStack MQTT Forwarder (version: 4.2.3, docs: https://www.chirpstack.io/)
chirpstack-mqtt-forwarder[1331]: Setting up Semtech UDP Packet Forwarder backend
chirpstack-mqtt-forwarder[1331]: Setting up Semtech UDP packet-forwarder backend
chirpstack-mqtt-forwarder[1331]: Binding UDP socket, bind: 0.0.0.0:1700
monit[1010]: ‘chirpstack-mqtt-forwarder’ process is running with pid 1331
chirpstack-mqtt-forwarder[1331]: PUSH_DATA received, random_token: 3240, remote: 127.0.0.1:59041
chirpstack-mqtt-forwarder[1331]: Sending PUSH_ACK, random_token: 3240 remote: 127.0.0.1:59041
chirpstack-mqtt-forwarder[1331]: Handle PUSH_DATA error: STATE is not set, remote: 127.0.0.1:59041
chirpstack-mqtt-forwarder[1331]: PULL_DATA received, random_token: 2728, remote: 127.0.0.1:39718
chirpstack-mqtt-forwarder[1331]: Sending PULL_ACK, random_token: 2728, remote: 127.0.0.1:39718
chirpstack-mqtt-forwarder[1331]: Received Gateway ID from backend, gateway_id: 7076xxxxxxxxxxxx
chirpstack mqtt forwarder configuration, where certs and key are the ones generated in the chirpstack gateway web ui. When using those certificates from the mosquitto_sub I can connect to the mosquitto of the chirpstack.
