For sure. Please find them here.
1. global_conf.json:
“SX1301_conf”: {
“lorawan_public”: true,
“antenna_gain”: 0,
“clksrc”: 1,
“radio_0”: {
“enable”: true,
“type”: “SX1257”,
“freq”: 867500000,
“tx_enable”: true,
“tx_notch_freq”: 129000,
“tx_freq_min”: 863000000,
“tx_freq_max”: 870000000
“radio_1”: {
“enable”: true,
“type”: “SX1257”,
“freq”: 868500000,
“tx_enable”: false
“chan_multiSF_0”: { “enable”: true, “radio”: 0, “if”: -400000 },
“chan_multiSF_1”: { “enable”: true, “radio”: 0, “if”: -200000 },
“chan_multiSF_2”: { “enable”: true, “radio”: 0, “if”: 0 },
“chan_multiSF_3”: { “enable”: true, “radio”: 0, “if”: 200000 },
“chan_multiSF_4”: { “enable”: true, “radio”: 0, “if”: 400000 },
“chan_multiSF_5”: { “enable”: true, “radio”: 1, “if”: -400000 },
“chan_multiSF_6”: { “enable”: true, “radio”: 1, “if”: -200000 },
“chan_multiSF_7”: { “enable”: true, “radio”: 1, “if”: 0 },
“chan_Lora_std”: {
“enable”: true,
“radio”: 1,
“if”: -200000,
“bandwidth”: 250000,
“spread_factor”: 7
“chan_FSK”: {
“enable”: true,
“radio”: 1,
“if”: 300000,
“bandwidth”: 125000,
“datarate”: 50000
“tx_lut_0”: {“dig_gain”: 0, “pa_gain”: 0, “mix_gain”: 8, “rf_power”: 0}
“gateway_conf”: {
“server_address”: “xxxxx.netop.io”,
“serv_port_up”: 1700,
“serv_port_down”: 1700,
“keepalive_interval”: 10,
“stat_interval”: 30,
“push_timeout_ms”: 100,
“forward_crc_valid”: true,
“forward_crc_error”: false,
“forward_crc_disabled”: false,
“autoquit_threshold”: 3,
“gps_tty_path”: “/dev/nmea”
2. local_conf.json
“SX1301_conf”: {
“radio_0”: {
“rssi_offset”: -nan
“radio_1”: {
“rssi_offset”: -nan
“tx_lut_0”: {
“dig_gain”: 3,
“pa_gain”: 3,
“mix_gain”: 15,
“rf_power”: -1
“tx_lut_1”: {
“dig_gain”: 3,
“pa_gain”: 3,
“mix_gain”: 15,
“rf_power”: -1
“tx_lut_2”: {
“dig_gain”: 3,
“pa_gain”: 3,
“mix_gain”: 15,
“rf_power”: -1
“tx_lut_3”: {
“dig_gain”: 3,
“pa_gain”: 3,
“mix_gain”: 15,
“rf_power”: -1
“tx_lut_4”: {
“dig_gain”: 3,
“pa_gain”: 3,
“mix_gain”: 15,
“rf_power”: -1
“tx_lut_5”: {
“dig_gain”: 3,
“pa_gain”: 3,
“mix_gain”: 15,
“rf_power”: -1
“tx_lut_6”: {
“dig_gain”: 3,
“pa_gain”: 3,
“mix_gain”: 15,
“rf_power”: -1
“tx_lut_7”: {
“dig_gain”: 3,
“pa_gain”: 3,
“mix_gain”: 15,
“rf_power”: -1
“tx_lut_8”: {
“dig_gain”: 3,
“pa_gain”: 3,
“mix_gain”: 15,
“rf_power”: -1
“tx_lut_9”: {
“dig_gain”: 3,
“pa_gain”: 3,
“mix_gain”: 15,
“rf_power”: -1
“tx_lut_10”: {
“dig_gain”: 3,
“pa_gain”: 3,
“mix_gain”: 15,
“rf_power”: -1
“tx_lut_11”: {
“dig_gain”: 3,
“pa_gain”: 3,
“mix_gain”: 15,
“rf_power”: -1
“tx_lut_12”: {
“dig_gain”: 3,
“pa_gain”: 3,
“mix_gain”: 15,
“rf_power”: -1
“tx_lut_13”: {
“dig_gain”: 3,
“pa_gain”: 3,
“mix_gain”: 15,
“rf_power”: -1
“tx_lut_14”: {
“dig_gain”: 3,
“pa_gain”: 3,
“mix_gain”: 15,
“rf_power”: -1
“tx_lut_15”: {
“dig_gain”: 3,
“pa_gain”: 3,
“mix_gain”: 15,
“rf_power”: -1
3. loraboard_conf.json
“SX1301_conf”: {
“radio_0”: {
“rssi_offset”: -nan
“radio_1”: {
“rssi_offset”: -nan
“tx_lut_0”: {
“dig_gain”: 3,
“pa_gain”: 3,
“mix_gain”: 15,
“rf_power”: -1
“tx_lut_1”: {
“dig_gain”: 3,
“pa_gain”: 3,
“mix_gain”: 15,
“rf_power”: -1
“tx_lut_2”: {
“dig_gain”: 3,
“pa_gain”: 3,
“mix_gain”: 15,
“rf_power”: -1
“tx_lut_3”: {
“dig_gain”: 3,
“pa_gain”: 3,
“mix_gain”: 15,
“rf_power”: -1
“tx_lut_4”: {
“dig_gain”: 3,
“pa_gain”: 3,
“mix_gain”: 15,
“rf_power”: -1
“tx_lut_5”: {
“dig_gain”: 3,
“pa_gain”: 3,
“mix_gain”: 15,
“rf_power”: -1
“tx_lut_6”: {
“dig_gain”: 3,
“pa_gain”: 3,
“mix_gain”: 15,
“rf_power”: -1
“tx_lut_7”: {
“dig_gain”: 3,
“pa_gain”: 3,
“mix_gain”: 15,
“rf_power”: -1
“tx_lut_8”: {
“dig_gain”: 3,
“pa_gain”: 3,
“mix_gain”: 15,
“rf_power”: -1
“tx_lut_9”: {
“dig_gain”: 3,
“pa_gain”: 3,
“mix_gain”: 15,
“rf_power”: -1
“tx_lut_10”: {
“dig_gain”: 3,
“pa_gain”: 3,
“mix_gain”: 15,
“rf_power”: -1
“tx_lut_11”: {
“dig_gain”: 3,
“pa_gain”: 3,
“mix_gain”: 15,
“rf_power”: -1
“tx_lut_12”: {
“dig_gain”: 3,
“pa_gain”: 3,
“mix_gain”: 15,
“rf_power”: -1
“tx_lut_13”: {
“dig_gain”: 3,
“pa_gain”: 3,
“mix_gain”: 15,
“rf_power”: -1
“tx_lut_14”: {
“dig_gain”: 3,
“pa_gain”: 3,
“mix_gain”: 15,
“rf_power”: -1
“tx_lut_15”: {
“dig_gain”: 3,
“pa_gain”: 3,
“mix_gain”: 15,
“rf_power”: -1
Thank you!
Zafer
