I am attempting to install the gateway bridge on a Raspberry Pi with Raspian using the documentation located within the chirpstack site:
gateway-bridge/install/debian/
When attempting to activate the repository per the instructions I receive an error and cannot proceed further.
Output of the two commands
sudo apt-key adv --keyserver keyserver.ubuntu.com --recv-keys 1CE2AFD36DBCCA00*
gpg: keyserver receive failed: Server indicated a failure
sudo apt update*
E: The repository ’ xxxxxxxxxx/packages/3.x/deb stable InRelease’ is not signed.
N: Updating from such a repository can’t be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
In searching for solutions, I noted a prior exchange in the forum suggests this was an issue with the key server.
unable-to-locate-package-chipstack-gateway-bridge-key-expired/7044
Any guidance to correct or work around to perform the installation is appreciated. thanks in advance.
I edited links since i am a new user
