Or maybe attacking this at another angle… There is a TTN custom encoder for this device published by the manufacturer. However, the function format and return format look different than the Application server wants.
Any advice on how to use this encoder with Chirpstack?
It is a bit confusing for the novice as the skeleton function shows 3 parameters, but the on-screen text only says 2. And this manufacturer encoder returns both bytes and port. I have yet to find a working example of an Encoder for chirpstack anywhere in my searches either.
Skeleton function (3 parameter):
function Encode(fPort, obj, variables) {
On-Screen text (2 parameters):
Encoder from manufacturer:
function Encoder(data) {
var ret = [];
var port = 100;
check_encode("device_eui",
function (value) {
function () {
ret = ret.concat(ret, [0x00])
check_encode("app_eui",
function (value) {
function () {
ret = ret.concat(ret, [0x01])
check_encode("app_key",
function (value) {
function () {
ret = ret.concat(ret, [0x02])
check_encode("device_address",
function (value) {
function () {
ret = ret.concat(ret, [0x03])
check_encode("network_session_key",
function (value) {
function () {
ret = ret.concat(ret, [0x04])
check_encode("app_session_key",
function (value) {
function () {
ret = ret.concat(ret, [0x05])
check_encode("lorawan_join_mode",
function (value) {
var converted = [0x10 | 0x80,
((value & 0x1) << 7), 0x00];
ret = ret.concat(converted);
function () {
ret = ret.concat([0x10])
check_encode("loramac_opts",
function (value) {
var converted = [0x11 | 0x80, 0x00,
((value.loramac_confirm_mode & 0x1) << 0) |
((value.loramac_sync_word & 0x1) << 1) |
((value.loramac_duty_cycle & 0x1) << 2) |
((value.loramac_adr & 0x1) << 3)];
function () {
ret = ret.concat([0x11])
check_encode("loramac_dr_tx",
function (value) {
var converted = [0x12 | 0x80,
((value.dr_number & 0xf) << 0),
((value.tx_power_number & 0xf) << 0)];
function () {
ret = ret.concat([0x12])
check_encode("loramac_rx2",
function (value) {
var converted = [0x13 | 0x80,
(value.frequency >> 24) & 0xff, (value.frequency >> 16) & 0xff, (value.frequency >> 8) & 0xff, value.frequency & 0xff,
value.dr_number & 0xff];
function () {
ret = ret.concat([0x13])
check_encode("seconds_per_core_tick",
function (value) {
var converted = [0x20 | 0x80,
(value >> 24) & 0xff, (value >> 16) & 0xff, (value >> 8) & 0xff, value & 0xff];
function () {
ret = ret.concat([0x20])
check_encode("tick_per_battery",
function (value) {
var converted = [0x21 | 0x80,
function () {
ret = ret.concat([0x21])
check_encode("tick_per_ambient_temperature",
function (value) {
var converted = [0x22 | 0x80,
function () {
ret = ret.concat([0x22])
check_encode("tick_per_relative_humidity",
function (value) {
var converted = [0x23 | 0x80,
function () {
ret = ret.concat([0x23])
check_encode("tick_per_reed_switch",
function (value) {
var converted = [0x24 | 0x80,
function () {
ret = ret.concat([0x24])
check_encode("tick_per_light",
function (value) {
var converted = [0x25 | 0x80,
function () {
ret = ret.concat([0x25])
check_encode("tick_per_accelerometer",
function (value) {
var converted = [0x26 | 0x80,
function () {
ret = ret.concat([0x26])
check_encode("tick_per_mcu_temperature",
function (value) {
var converted = [0x27 | 0x80,
function () {
ret = ret.concat([0x27])
check_encode("tick_per_pir",
function (value) {
var converted = [0x28 | 0x80,
function () {
ret = ret.concat([0x28])
check_encode("tick_per_external_connector",
function (value) {
var converted = [0x29 | 0x80,
function () {
ret = ret.concat([0x29])
check_encode("reed_mode",
function (value) {
var converted = [0x2A | 0x80,
((value.rising_edge_enabled & 0x1) << 0) |
((value.falling_edge_enabled & 0x1) << 1)];
function () {
ret = ret.concat([0x2A])
check_encode("reed_switch_count_threshold",
function (value) {
var converted = [0x2B | 0x80,
function () {
ret = ret.concat([0x2B])
check_encode("reed_tx",
function (value) {
var converted = [0x2C | 0x80,
((value.report_state_enabled & 0x1) << 0) |
((value.report_count_enabled & 0x1) << 1)];
function () {
ret = ret.concat([0x2C])
check_encode("external_connector",
function (value) {
var converted = [0x2D | 0x80,
((value.falling_edge_enabled & 0x1) << 1) |
((value.mode & 0x1) << 7)];
function () {
ret = ret.concat([0x2D])
check_encode("external_connector_count_threshold",
function (value) {
var converted = [0x2E | 0x80,
function () {
ret = ret.concat([0x2E])
check_encode("external_connector_tx",
function (value) {
var converted = [0x2F | 0x80,
function () {
ret = ret.concat([0x2F])
check_encode("impact_event_threshold",
function (value) {
var converted = [0x30 | 0x80,
function () {
ret = ret.concat([0x30])
check_encode("acceleration_event_threshold",
function (value) {
var converted = [0x31 | 0x80,
function () {
ret = ret.concat([0x31])
check_encode("accelerometer_tx",
function (value) {
var converted = [0x32 | 0x80,
((value.report_alarm_enabled & 0x1) << 0) |
((value.report_magnitude_enabled & 0x1) << 4) |
((value.report_vector_enabled & 0x1) << 5)];
function () {
ret = ret.concat([0x32])
check_encode("acceleration_impact_grace_period",
function (value) {
var converted = [0x33 | 0x80,
function () {
ret = ret.concat([0x33])
check_encode("accelerometer",
function (value) {
var converted = [0x34 | 0x80,
((value.impact_threshold_enabled & 0x1) << 0) |
((value.acceleration_threshold_enabled & 0x1) << 1) |
((value.xaxis_enabled & 0x1) << 4) |
((value.yaxis_enabled & 0x1) << 5) |
((value.zaxis_enabled & 0x1) << 6) |
((value.poweron & 0x1) << 7)];
function () {
ret = ret.concat([0x34])
check_encode("sensitivity",
function (value) {
var converted = [0x35 | 0x80,
((value.accelerometer_sample_rate & 0x7) << 0) |
((value.accelerometer_measurement_range & 0x3) << 4)];
function () {
ret = ret.concat([0x35])
check_encode("impact_alarm_grace_period",
function (value) {
var converted = [0x36 | 0x80,
function () {
ret = ret.concat([0x36])
check_encode("impact_alarm_threshold_count",
function (value) {
var converted = [0x37 | 0x80,
function () {
ret = ret.concat([0x37])
check_encode("impact_alarm_threshold_period",
function (value) {
var converted = [0x38 | 0x80,
function () {
ret = ret.concat([0x38])
check_encode("temperature_relative_humidity_sample_period_idle",
function (value) {
var converted = [0x39 | 0x80,
function () {
ret = ret.concat([0x39])
check_encode("temperature_relative_humidity_sample_period_active",
function (value) {
var converted = [0x3A | 0x80,
function () {
ret = ret.concat([0x3A])
check_encode("ambient_temperature_threshold",
function (value) {
var converted = [0x3B | 0x80,
value.high & 0xff,
value.low & 0xff];
function () {
ret = ret.concat([0x3B])
check_encode("ambient_temperature_threshold_enabled",
function (value) {
var converted = [0x3C | 0x80,
value & 0xff];
function () {
ret = ret.concat([0x3C])
check_encode("relative_humidity_threshold",
function (value) {
var converted = [0x3D | 0x80,
value.high & 0xff,
value.low & 0xff];
function () {
ret = ret.concat([0x3D])
check_encode("relative_humidity_threshold_enabled",
function (value) {
var converted = [0x3E | 0x80,
value & 0xff];
function () {
ret = ret.concat([0x3E])
check_encode("mcu_temperature_sample_period_idle",
function (value) {
var converted = [0x40 | 0x80,
function () {
ret = ret.concat([0x40])
check_encode("mcu_temperature_sample_period_active",
function (value) {
var converted = [0x41 | 0x80,
function () {
ret = ret.concat([0x41])
check_encode("mcu_temperature_threshold",
function (value) {
var converted = [0x42 | 0x80,
value.high & 0xff,
value.low & 0xff];
function () {
ret = ret.concat([0x42])
check_encode("mcu_temperature_threshold_enabled",
function (value) {
var converted = [0x43 | 0x80,
value & 0x1];
function () {
ret = ret.concat([0x43])
check_encode("analog_sample_period_idle",
function (value) {
var converted = [0x44 | 0x80,
function () {
ret = ret.concat([0x44])
check_encode("analog_sample_period_active",
function (value) {
var converted = [0x45 | 0x80,
function () {
ret = ret.concat([0x45])
check_encode("analog_input_threshold",
function (value) {
var converted = [0x46 | 0x80,
(value.high >> 16) & 0xff,
(value.high) & 0xff,
(value.low >> 16) & 0xff,
(value.low) & 0xff];
function () {
ret = ret.concat([0x46])
check_encode("light_sample_period",
function (value) {
var converted = [0x47 | 0x80,
function () {
ret = ret.concat([0x47])
check_encode("light",
function (value) {
var converted = [0x48 | 0x80,
(value.threshold & 0x3f) |
(value.threshold_enabled & 0x1) << 7];
function () {
ret = ret.concat([0x48])
check_encode("light_tx",
function (value) {
var converted = [0x49 | 0x80,
(value.state_reported & 0x1) |
(value.intensity_reported & 0x1) << 1];
function () {
ret = ret.concat([0x49])
check_encode("analog_input_threshold_enabled",
function (value) {
var converted = [0x4A | 0x80,
value.analog_input_threshold_enabled & 0x1];
function () {
ret = ret.concat([0x4A])
check_encode("pir_grace_period",
function (value) {
var converted = [0x50 | 0x80,
function () {
ret = ret.concat([0x50])
check_encode("pir_threshold",
function (value) {
var converted = [0x51 | 0x80,
function () {
ret = ret.concat([0x51])
check_encode("pir_threshold_period",
function (value) {
var converted = [0x52 | 0x80,
function () {
ret = ret.concat([0x52])
check_encode("pir_mode",
function (value) {
var converted = [0x53 | 0x80,
((value.motion_count_reported & 0x1) << 0) |
((value.motion_state_reported & 0x1) << 1) |
((value.event_transmission_enabled & 0x1) << 6) |
((value.transducer_enabled & 0x1) << 7)];
function () {
ret = ret.concat([0x53])
check_encode("moisture_sample_period",
function (value) {
var converted = [0x5A | 0x80,
value & 0xff];
function () {
ret = ret.concat([0x5A])
check_encode("moisture_threshold",
function (value) {
var converted = [0x5B | 0x80,
value & 0xff];
function () {
ret = ret.concat([0x5B])
check_encode("moisture_sensing_enabled",
function (value) {
var converted = [0x5C | 0x80,
value & 0xff];
function () {
ret = ret.concat([0x5C])
check_encode("moisture_caliberation_dry",
function (value) {
var converted = [0x5D | 0x80,
value & 0xff];
function () {
ret = ret.concat([0x5D])
check_encode("write_to_flash",
function (value) {
var converted = [0x70 | 0x80,
((value.app_configuration & 0x1) << 5) |
((value.lora_configuration & 0x1) << 6),
((value.restart_sensor & 0x1) << 0)];
function () {
ret = ret.concat([0x70])
check_encode("firmware_version",
function (value) {
function () {
ret = ret.concat(ret, [0x71])
check_encode("configuration_factory_reset",
function (value) {
var converted = [0x72 | 0x80,
value & 0xff];
function () {
ret = ret.concat([0x72])
check_encode("payload",
function (value) {
var converted = base64ToArray(value);
function () {
function check_encode(prop_name, do_write, do_read) {
if (data.hasOwnProperty(prop_name)) {
var obj = data[prop_name];
if (obj.hasOwnProperty("access")) {
var access_value = obj.access;
if (access_value == "write") {
do_write(obj.value);
} else if (access_value == "read") {
do_read();
} else if (obj.hasOwnProperty("value")) {
function atob(input) {
var chars = 'ABCDEFGHIJKLMNOPQRSTUVWXYZabcdefghijklmnopqrstuvwxyz0123456789+/=';
var str = String(input).replace(/[=]+$/, ''); // #31: ExtendScript bad parse of /=
if (str.length % 4 === 1) {
throw new InvalidCharacterError("'atob' failed: The string to be decoded is not correctly encoded.");
for (
var bc = 0, bs, buffer, idx = 0, output = '';
buffer = str.charAt(idx++);
~buffer && (bs = bc % 4 ? bs * 64 + buffer : buffer, bc++ % 4) ? output += String.fromCharCode(255 & bs >> (-2 * bc & 6)) : 0
buffer = chars.indexOf(buffer);
return output;
function base64ToArray(base64) {
var binary_string = atob(base64);
var len = binary_string.length;
var result = [];
for (var i = 0; i < len; i++) {
result.push(binary_string.charCodeAt(i));
return result;
return {
'bytes': ret,
'port': port
My initial thought:
- Change manufacturer encoder to only return the bytes, and not the port (as the text says it must return an array of bytes - doesn’t mention anything about returning the port (?).
return {
'bytes': ret
- Make wrapper to call the manufacturer Encoder function:
function Encode(fPort, obj) {
return Encoder(obj);
