Kubernetes - Redis Headless Service - Connection Lost on Pod restart
in my testing I discovered an issue in the connection between Chirpstack and a Redis cluster in Kubernetes.
I use a headless service which should resolve all 6 of the present Redis instance IPs, so that the Chirpstack Pods can open their dedicated connections to the Redis instances directly.
I discovered, that Chirpstack always connects to the first 3 of them.
Additionally when a Redis pod restarts for some reason, Chirpstack is not resolving the IPs again and throws errors until the Chirpstack pod is restarted and the IPs are resolved again.
What is the preferred way to use Redis cluster in Kubernetes?
# Redis configuration.
[redis]
    servers=[
        "redis://:$CHIRPSTACK_REDIS_PASSWORD@chirpstackv4-redis-cluster-headless",
    # Redis Cluster.
    # instance.
    cluster=true
~ $ nslookup chirpstackv4-redis-cluster-headless
Server:         172.29.0.10
Address:        172.29.0.10:53
Address: 172.28.58.33
Address: 172.28.78.17
Address: 172.28.129.12
Address: 172.28.131.17
Address: 172.28.37.30
Address: 172.28.145.15
~ $ netstat -nputw | grep 172.28.58.33
tcp        0      0 172.28.106.125:58418    172.28.58.33:6379       ESTABLISHED 1/chirpstack
tcp        0      0 172.28.106.125:58468    172.28.58.33:6379       ESTABLISHED 1/chirpstack
tcp        0      0 172.28.106.125:58416    172.28.58.33:6379       ESTABLISHED 1/chirpstack
tcp        0      0 172.28.106.125:58536    172.28.58.33:6379       ESTABLISHED 1/chirpstack
tcp        0      0 172.28.106.125:58520    172.28.58.33:6379       ESTABLISHED 1/chirpstack
tcp        0      0 172.28.106.125:58454    172.28.58.33:6379       ESTABLISHED 1/chirpstack
tcp        0      0 172.28.106.125:58560    172.28.58.33:6379       ESTABLISHED 1/chirpstack
tcp        0      0 172.28.106.125:58506    172.28.58.33:6379       ESTABLISHED 1/chirpstack
tcp        0      0 172.28.106.125:58422    172.28.58.33:6379       ESTABLISHED 1/chirpstack
tcp        0      0 172.28.106.125:58474    172.28.58.33:6379       ESTABLISHED 1/chirpstack
~ $ netstat -nputw | grep 172.28.78.17
tcp        0      0 172.28.106.125:52654    172.28.78.17:6379       ESTABLISHED 1/chirpstack
tcp        0      0 172.28.106.125:52696    172.28.78.17:6379       ESTABLISHED 1/chirpstack
tcp        0      0 172.28.106.125:52656    172.28.78.17:6379       ESTABLISHED 1/chirpstack
tcp        0      0 172.28.106.125:52658    172.28.78.17:6379       ESTABLISHED 1/chirpstack
tcp        0      0 172.28.106.125:52710    172.28.78.17:6379       ESTABLISHED 1/chirpstack
tcp        0      0 172.28.106.125:52740    172.28.78.17:6379       ESTABLISHED 1/chirpstack
tcp        0      0 172.28.106.125:52682    172.28.78.17:6379       ESTABLISHED 1/chirpstack
tcp        0      0 172.28.106.125:52666    172.28.78.17:6379       ESTABLISHED 1/chirpstack
tcp        0      0 172.28.106.125:52726    172.28.78.17:6379       ESTABLISHED 1/chirpstack
tcp        0      0 172.28.106.125:52742    172.28.78.17:6379       ESTABLISHED 1/chirpstack
~ $ netstat -nputw | grep 172.28.129.12
tcp        0      0 172.28.106.125:47842    172.28.129.12:6379      ESTABLISHED 1/chirpstack
tcp        0      0 172.28.106.125:47856    172.28.129.12:6379      ESTABLISHED 1/chirpstack
tcp        0      0 172.28.106.125:47880    172.28.129.12:6379      ESTABLISHED 1/chirpstack
tcp        0      0 172.28.106.125:47872    172.28.129.12:6379      ESTABLISHED 1/chirpstack
tcp        0      0 172.28.106.125:47892    172.28.129.12:6379      ESTABLISHED 1/chirpstack
tcp        0      0 172.28.106.125:47860    172.28.129.12:6379      ESTABLISHED 1/chirpstack
tcp        0      0 172.28.106.125:47850    172.28.129.12:6379      ESTABLISHED 1/chirpstack
tcp        0      0 172.28.106.125:47838    172.28.129.12:6379      ESTABLISHED 1/chirpstack
tcp        0      0 172.28.106.125:47824    172.28.129.12:6379      ESTABLISHED 1/chirpstack
tcp        0      0 172.28.106.125:47884    172.28.129.12:6379      ESTABLISHED 1/chirpstack
~ $ netstat -nputw | grep 172.28.131.17
~ $ netstat -nputw | grep 172.28.37.30
~ $ netstat -nputw | grep 172.28.145.15
Thanks.
