Hi, I have been trying to set up ChirpStack in a Kubernetes space for a while now. Seem to have app-server, net-server, gateway-bridge etc done, but mosquitto doesn’t seem to be working for me, and I can’t find any resources online that answer this particular question(and I’m not very sure how exactly to ask it).
Above are some of the pods I have atm. App-server, net-server, gateway-bridge all spin up and run, however the Mosquitto broker moves to ‘Complete’ and goes right into the CrashLoopBackOff. This obviously causes the mqtt integration part of the components to fail, and a colleague who’s a bit more savvy with K8s has told me the ports configured are not listening, meaning I can’t even access the app-server UI atm. While I might be wrong (and if I am, I would be happy to be corrected so long as I can reach the answer) it appears it’s down to Mosquitto.
I have figured it might have been something to do with a lack of config, so I’ve spent a few days putting together the mosquitto.conf file with “allow_anonymous true” hoping to get a connection from any of my ChirpStack components, but the logs just indicate an mqtt connection refused error(now gone to timeout since mqtt broker always his Crash loop).
output of kubectl logs chirpstack-application-server
Because no connection could be made, I tried to add in the password_file and make allow_anonymous false. Below is my current config if anyone might have a general idea what is wrong.
Thanks in advance.
configMap-1.yml
kind: ConfigMap
metadata:
namespace: ****
labels:
app: chirpstack-mosquitto
data:
password_file.txt: |
admin:admin
user:user
app-server:app-server
net-server:net-server
gateway-bridge:gateway-bridge
configMap.yml
kind: ConfigMap
metadata:
namespace: ****
labels:
data:
mosquitto.conf: |
persistence true
persistence_location /mosquitto/data/
# per_listener_settings false
log_dest stdout
# listener 1886
listener 1883
protocol mqtt
# Defaults to false, unless there are no listeners defined in the configuration
# file, in which case it is set to true, but connections are only allowed from
# the local machine.
password_file /.config/mosquitto/auth/password_file.txt
# cafile: /mosquitto/config/certs/ca.crt
# certfile: /mosquitto/config/certs/server.crt
# keyfile: /mosquitto/config/certs/server.key
require_certificate false
use_identity_as_username false
deployment.yml
kind: Deployment
metadata:
namespace: ****
spec:
replicas: 1
selector:
matchLabels:
template:
metadata:
labels:
spec:
containers:
- name: chirpstack-mosquitto
image: ****/chirpstack/eclipse-mosquitto:1.6.12
ports:
- containerPort: 1883
volumeMounts:
- name: password-file
mountPath: /.config/mosquitto/auth/password_file.txt
subPath: password_file.txt
- name: mosquitto-data
mountPath: /mosquitto/data
- name: mosquitto-log
mountPath: /mosquitto/log
- name: config-file
mountPath: /.config/mosquitto/mosquitto.conf
subPath: mosquitto.conf
securityContext:
runAsNonRoot: true
fsGroup: 1
runAsGroup: 1000
runAsUser: 1000
supplementalGroups:
- 1
volumes:
- name: config-file
configMap:
configMap:
emptyDir: {}
emptyDir: {}
service.yml
kind: Service
metadata:
namespace: 186215-poc
spec:
type: ClusterIP
ports:
- name: mqtt
port: 1883
targetPort: 1883
protocol: TCP
selector:
