Hi everyone,
I have setup the newest chirpstack server with docker-compose, then a tenant, added a gateway, an application, a device profile and an LMIC device according to Devices - ChirpStack open-source LoRaWAN® Network Server documentation → Generic Arduino LMIC-based devices
The gateway is online.
I start my arduino device an I see the following:
Starting
DEVEUI: 0xD4, 0x17, 0x45, 0x48, 0x5D, 0x16, 0x5B, 0x67 (in the ardunio code as lsb)
Packet queued
1890: EV_JOINING
84041: EV_TXSTART
477217: EV_JOIN_TXCOMPLETE: no JoinAccept
From the logs of docker-compose I see:
chirpstack_1 | 2023-12-22T14:55:14.205019Z INFO up{deduplication_id=0da12c1f-4ec0-4ab6-91f6-3ed96dac4184}:join_request{dev_eui="675b165d484517d4"}: chirpstack::storage::device_keys: Device-nonce validated, join-nonce incremented and stored dev_eui=675b165d484517d4 dev_nonce=65474
chirpstack_1 | 2023-12-22T14:55:14.207138Z INFO up{deduplication_id=0da12c1f-4ec0-4ab6-91f6-3ed96dac4184}:join_request{dev_eui="675b165d484517d4"}: chirpstack::storage::device_session: Device-session saved dev_eui=675b165d484517d4 dev_addr=00be0d1b
chirpstack_1 | 2023-12-22T14:55:14.208644Z INFO up{deduplication_id=0da12c1f-4ec0-4ab6-91f6-3ed96dac4184}:join_request{dev_eui="675b165d484517d4"}: chirpstack::storage::device_queue: Device queue flushed dev_eui=675b165d484517d4 count=0
chirpstack_1 | 2023-12-22T14:55:14.212739Z INFO up{deduplication_id=0da12c1f-4ec0-4ab6-91f6-3ed96dac4184}:join_request{dev_eui="675b165d484517d4"}: chirpstack::storage::device: Enabled class updated dev_eui=675b165d484517d4 enabled_class=A
chirpstack_1 | 2023-12-22T14:55:14.216221Z INFO up{deduplication_id=0da12c1f-4ec0-4ab6-91f6-3ed96dac4184}:join_request{dev_eui="675b165d484517d4"}: chirpstack::storage::device: Updated DevAddr dev_eui=675b165d484517d4 dev_addr=00be0d1b
chirpstack_1 | 2023-12-22T14:55:14.219106Z INFO up{deduplication_id=0da12c1f-4ec0-4ab6-91f6-3ed96dac4184}:join_request{dev_eui="675b165d484517d4"}: chirpstack::storage::device: Updated JoinEUI dev_eui=675b165d484517d4 join_eui=0000000000000000
chirpstack_1 | 2023-12-22T14:55:14.223578Z INFO up{deduplication_id=0da12c1f-4ec0-4ab6-91f6-3ed96dac4184}:join_request{dev_eui="675b165d484517d4"}:join_accept{downlink_id=3843883202}: chirpstack::storage::downlink_frame: Downlink-frame saved downlink_id=3843883202
At the end a join_accept. But this doesn’t seem to be acknowledged by my arduino device.
Does anybody has an idea?
Best regards
Joachim
p.s.: Is the LMIC code still supported and checked as I believe the code worked in earlier versions of chirpstack and lora server?
