I have setup a Rak Pilot Pro with loraserver (after setting it first with TTN). I switched to loraserver as I am looking for building a small (~10 devices, single GW) private network for a proof of concept.
The setup was easy and my end device is able to join. I can see the activation from the loraserver UI. All the keys are matching and even got 1 uplink with sensor data.
However, after restarting the end device and a second successful join, now the loraserver is no longer seeing the device. Although, it appears the end device and the packet forwarder are sending the sensor data. It doesn’t seem to each the app server.
I am completely new on how to troubleshoot the lorasever. Any ideas what could be wrong, or where/how I should start investigating.
I am using loraserver 3.0.1 with pretty much all default configuration. The RAKWirless people have done a good job in integrating loraserver, it seems.
EDIT: I went in the APP CONFIGURATION and updated it without changing anything and now the device is seen, but still no Device Data is showing. The page just continuously spins.
Thanks in advance for helping.
Amir.
