Still using Chirpstack v3. This might not be relevant to v4.
I don’t think I ever changed anything to the default log config and I realized recently that chirpstack logs took a lot of space, in fact much more than the DB that actually stores the data.
This applies to both network and application server.
I found config tips in the docs
- Configuration - ChirpStack open-source LoRaWAN<sup>®</sup> Network Server
Those are not in the default configuration.
I modified the network and application server configs as indicated, setting warning as log level:
[general]
# Log level
log_level=3
# Log to syslog.
# When set to true, log messages are being written to syslog.
log_to_syslog=false
The change has been taken into account after restart because I now only get messages of level >= warning.
However, those are still logged in syslog. I wonder why.
Also, I get a lot of those errors:
- get device-session error: object does not exist
- get device-session error: frame-counter did not increment
I’m not sure exactly why and as soon as all my applications work I assume this is noise. In any case, and unless I’m totally mistaken, those are not errors from the server perspective, those are client errors, like misconfigured devices. Shouldn’t those be info level, rather than error? Like, rejecting a user due to auth error, for instance, would be at most info level from server perspective. The point of setting to error is to limit the log to server errors.
My suggestion would be to make those info at most.
Sorry about bringing up questions about v3. I intend to migrate but there are things we still need to figure out.
