Price Range : up to €35 per sensor
Features : IP65 Waterproof
Measuring Range : -30°C to +85°C
Battery Level : must be transmitted as a data point.
Maximum Dimensions : 70mm x 70mm x 30mm
Any help with this appreciated ![]()
Can try Dragino nodes. Esp. the LSN50v2 based models or NB models (newer v3).
Confirmed all can send the battery level.
HI Do you look for the temperature sensor with probe or ambient?
If you want probe temperature sensor, you can check YL-104.
https://www.appconwireless.com/showpro.php?id=159
If you need ambient measurement, you can check YL-103.
https://www.appconwireless.com/showpro.php?id=155
I use Si7201 temperature & humidity sensors. They work well.
It’s only IP54 but maybe something to consider: The n-fuse STx (STa) environment sensor:
