This is how the loraserver configuration is going to look like
[general]
# Log level
log_level=4
# PostgreSQL settings.
# Please note that PostgreSQL 9.5+ is required.
[postgresql]
# PostgreSQL dsn (e.g.: postgres://user:password@hostname/database?sslmode=disable).
# Besides using an URL (e.g. 'postgres://user:password@hostname/database?sslmode=disable')
# it is also possible to use the following format:
# 'user=loraserver dbname=loraserver sslmode=disable'.
# The following connection parameters are supported:
# * dbname - The name of the database to connect to
# * user - The user to sign in as
# * password - The user's password
# * host - The host to connect to. Values that start with / are for unix domain sockets. (default is localhost)
# * port - The port to bind to. (default is 5432)
# * sslmode - Whether or not to use SSL (default is require, this is not the default for libpq)
# * fallback_application_name - An application_name to fall back to if one isn't provided.
# * connect_timeout - Maximum wait for connection, in seconds. Zero or not specified means wait indefinitely.
# * sslcert - Cert file location. The file must contain PEM encoded data.
# * sslkey - Key file location. The file must contain PEM encoded data.
# * sslrootcert - The location of the root certificate file. The file must contain PEM encoded data.
# Valid values for sslmode are:
# * disable - No SSL
dsn="postgres://localhost/loraserver_ns?sslmode=disable"
# Automatically apply database migrations.
# It is possible to apply the database-migrations by hand
# (see https://github.com/brocaar/loraserver/tree/master/migrations)
# or let LoRa App Server migrate to the latest state automatically, by using
# this setting. Make sure that you always make a backup when upgrading Lora
# App Server and / or applying migrations.
automigrate=true
# Redis settings
# Please note that Redis 2.6.0+ is required.
[redis]
# Redis url (e.g. redis://user:password@hostname/0)
# For more information about the Redis URL format, see:
# https://www.iana.org/assignments/uri-schemes/prov/redis
url="redis://localhost:6379"
# Network-server settings.
[network_server]
# Network identifier (NetID, 3 bytes) encoded as HEX (e.g. 010203)
net_id="010203"
# Time to wait for uplink de-duplication.
# This is the time that LoRa Server will wait for other gateways to receive
# the same uplink frame. Valid units are 'ms' or 's'.
deduplication_delay="200ms"
# Device session expiration.
# The TTL value defines the time after which a device-session expires
# after no activity. Valid units are 'ms', 's', 'm', 'h'. Note that these
# values can be combined, e.g. '24h30m15s'.
# Please note that this value has influence on the uplink / downlink
# roundtrip time. Setting this value too high means LoRa Server will be
# unable to respond to the device within its receive-window.
device_session_ttl="744h0m0s"
# Get downlink data delay.
# This is the time that LoRa Server waits between forwarding data to the
# application-server and reading data from the queue. A higher value
# means that the application-server has more time to schedule a downlink
# queue item which can be processed within the same uplink / downlink
# transaction.
get_downlink_data_delay="100ms"
# LoRaWAN regional band configuration.
# Note that you might want to consult the LoRaWAN Regional Parameters
# specification for valid values that apply to your region.
# See: https://www.lora-alliance.org/lorawan-for-developers
[network_server.band]
# LoRaWAN band to use.
# Valid values are:
# * AS_923
# * AU_915_928
# * CN_470_510
# * CN_779_787
# * EU_433
# * EU_863_870
# * IN_865_867
# * KR_920_923
# * US_902_928),
name="EU_863_870"
# Enforce 400ms dwell time
# Some band configurations define the max payload size for both dwell-time
# limitation enabled as disabled (e.g. AS 923). In this case the
# dwell time setting must be set to enforce the max payload size
# given the dwell-time limitation. For band configuration where the dwell-time is
# always enforced, setting this flag is not required.
dwell_time_400ms=false
# Enforce repeater compatibility
# Most band configurations define the max payload size for both an optional
# repeater encapsulation layer as for setups where a repeater will never
# be used. The latter case increases the max payload size for some data-rates.
# In case a repeater might used, set this flag to true.
repeater_compatible=false
# LoRaWAN network related settings.
# surrounded gateways.
installation_margin=10
# Class A RX1 delay
# 0=1sec, 1=1sec, ... 15=15sec. A higher value means LoRa Server has more
# time to respond to the device as the delay between the uplink and the
# first receive-window will be increased.
rx1_delay=1
# RX1 data-rate offset
# Please consult the LoRaWAN Regional Parameters specification for valid
# options of the configured network_server.band.name.
rx1_dr_offset=0
# RX2 data-rate (when set to -1, the default rx2 data-rate will be used)
rx2_dr=-1
# Enable only a given sub-set of channels
# Use this when ony a sub-set of the by default enabled channels are being
# used. For example when only using the first 8 channels of the US band.
# Example:
# enabled_uplink_channels=[0, 1, 2, 3, 4, 5, 6, 7]
enabled_uplink_channels=[]
# Extra channels to use for ISM bands that implement the CFList
# Use this for LoRaWAN regions where it is possible to extend the by default
# available channels with additional channels (e.g. the EU band).
# Note: the min_dr and max_dr are currently informative, but will be enforced
# in one of the next versions of LoRa Server!
# Example:
# [[network_server.network_settings.extra_channels]]
# frequency=867100000
# min_dr=0
# max_dr=5
# frequency=867300000
# min_dr=0
# max_dr=5
# frequency=867500000
# min_dr=0
# max_dr=5
# frequency=867700000
# min_dr=0
# max_dr=5
# frequency=867900000
# min_dr=0
# max_dr=5
# Network-server API
# This is the network-server API that is used by LoRa App Server or other
# custom components interacting with LoRa Server.
[network_server.api]
bind="0.0.0.0:8000"
# ca certificate used by the api server (optional)
ca_cert=""
# tls certificate used by the api server (optional)
tls_cert=""
# tls key used by the api server (optional)
tls_key=""
# Gateway API
# This API is used by the LoRa Channel Manager component to fetch
# channel configuration.
[network_server.gateway.api]
bind="0.0.0.0:8002"
# CA certificate used by the api server (optional)
ca_cert=""
tls_cert=""
tls_key=""
# JWT secret used by the gateway api server for gateway authentication / authorization
jwt_secret=""
# Gateway statistics settings.
[network_server.gateway.stats]
# Create non-existing gateways on receiving of stats
# When set to true, LoRa Server will create the gateway when it receives
# statistics for a gateway that does not yet exist.
create_gateway_on_stats=false
# Aggregation timezone
# This timezone is used for correctly aggregating the statistics (for example
# 'Europe/Amsterdam').
# To get the list of supported timezones by your PostgreSQL database,
# execute the following SQL query:
# select * from pg_timezone_names;
# When left blank, the default timezone of your database will be used.
timezone=""
# Aggregation intervals to use for aggregating the gateway stats
# Valid options: second, minute, hour, day, week, month, quarter, year.
# When left empty, no statistics will be stored in the database.
# Note, LoRa App Server expects at least "minute", "day", "hour"!
aggregation_intervals=["minute", "hour", "day"]
# MQTT gateway backend settings.
# This is the backend communicating with the LoRa gateways over a MQTT broker.
server="tcp://localhost:1883"
username=""
password=""
ca_cert=""
tls_cert=""
# TLS key file (optional)
tls_key=""
# Default join-server settings.
[join_server.default]
# hostname:port of the default join-server
# This API is provided by LoRa App Server.
server="http://localhost:8003"
# ca certificate used by the default join-server client (optional)
ca_cert=""
# tls certificate used by the default join-server client (optional)
tls_cert=""
# tls key used by the default join-server client (optional)
tls_key=""
# Network-controller configuration.
[network_contoller]
# hostname:port of the network-controller api server (optional)
server=""
# ca certificate used by the network-controller client (optional)
ca_cert=""
# tls certificate used by the network-controller client (optional)
tls_cert=""
# tls key used by the network-controller client (optional)
tls_key=""
