I am working on a project using LoRa 2.4GHz and need some assistance with configuration and performance.
Here are the details of my setup:
Development Environment: SES 8.18, nRF5 SDK Version 17.1, nRF52832.
Transceiver: E28-2G4M12S (SX1280).
Gateway: MikroTik wAP LR2 kit.
chirpstack --version 4.9.0
chirpstack-gateway-bridge version 4.0.11
I can send uplinks to the gateway, but I get the following error in the ChirpStack Gateway Bridge logs:
´nov 21 10:32:51 santos chirpstack-gateway-bridge[35649]: {“addr”:{“IP”:“192.168.88.1”,“Port”:57128,“Zone”:“”},“data_base64”:“AgGpAJNX70hTWDU5eyJyeHBrIjpbeyJjaGFuIjoxLCJjb2RyIjoiT0ZGIiwiZGF0YSI6IiIsImRhdHIiOiJTRjEyQlc4MTIiLCJmb2ZmIjotMTkwNTQ2LCJmcmVxIjoyNDc5LjAwMDAwMCwibHNuciI6LTI0LjAwMDAwMCwibW9kdSI6IkxPUkEiLCJyc3NpIjotMTA0LCJzaXplIjowLCJzdGF0IjoxLCJ0bXN0Ijo0NDUwNjc1NDR9XX0=”,“error”:“get uplink frames error: backend/semtechudp/packets: get uplink frame error: backend/semtechudp:packets: invalid CodR: OFF”,“level”:“error”,“msg”:“backend/semtechudp: could not handle packet”,“time”:“2024-11-21T10:32:51-03:00”}`
My chirpstack-gateway-brigde.toml:
# This configuration provides a Semtech UDP packet-forwarder backend and
# integrates with a MQTT broker. Many options and defaults have been omitted
# for simplicity.
# See https://www.chirpstack.io/gateway-bridge/install/config/ for a full
# configuration example and documentation.
[general]
log_level=4
log_json=true
[backend]
# Backend type.
type="semtech_udp"
# Semtech UDP packet-forwarder backend.
[backend.semtech_udp]
# ip:port to bind the UDP listener to
# Example: 0.0.0.0:1700 to listen on port 1700 for all network interfaces.
# This is the listener to which the packet-forwarder forwards its data
# so make sure the 'serv_port_up' and 'serv_port_down' from your
# packet-forwarder matches this port.
udp_bind = "192.168.88.254:1700"
# Skip the CRC status-check of received packets
# This is only has effect when the packet-forwarder is configured to forward
# LoRa frames with CRC errors.
skip_crc_check = false
# Integration configuration.
[integration]
# Payload marshaler.
# This defines how the MQTT payloads are encoded. Valid options are:
# * protobuf: Protobuf encoding
# * json: JSON encoding (easier for debugging, but less compact than 'protobuf')
marshaler="json"
# MQTT integration configuration.
[integration.mqtt]
# Event topic template.
event_topic_template="ism2400/gateway/{{ .GatewayID }}/event/{{ .EventType }}"
# Command topic template.
command_topic_template="ism2400/gateway/{{ .GatewayID }}/command/#"
# MQTT authentication.
[integration.mqtt.auth]
# Type defines the MQTT authentication type to use.
# Set this to the name of one of the sections below.
type="generic"
# Generic MQTT authentication.
server="tcp://192.168.88.254:1883"
username=""
password=""
