Hi brocaar,
The following error is returned from LoRa GW, would like to know when such an error occurs ?
“txpk_ack”:{“error”:“COLLISION_PACKET”}
Thank you,
Regards,
Sharmila
Hi brocaar,
Thank you,
Regards,
Sharmila
When there is a collision with regards to scheduling a downlink
A gateway can only send a single downlink frame at a time. Depending the spreading-factor, sending a frame could block the gateway for ~ 1 second. When you are trying to send an other downlink within the same timeframe, you will get this error.
Hi Brocaar,
Thanks for the quick reply
Thank you
Regard,
Sharmila
