LoRa Gateway OS: JoinAccept is not received
I have only been experimenting with LoRa for a few days and still have a few problems. Thanks to the good documentation I was able to get the gateway up and running. Now I would like to connect my first device for testing…
My Hardware:
I used a simple Arduino example script (“hello world”) to activate the device.
My Problem:
In the Live Frames tab of the LoRaServer for the Device you can see the Join Request in the UPLINK. Subsequently, the gateway also sends a JoinAccept in the downlink. However, the JoinAccept is not received by my device and it continuously sends new JoinAccept requests.
I am still very inexperienced with LoRa and can’t get any further at this point. I hope you can help me. In the following I have added my current gateway config.
Thanks a lot!
Current Gateway Configuration:
Service profile:
  • Device-status request frequency: 0
  • Minimum allowed data-rate *: 0
  • Maximum allowed data-rate *: 0
Service profile:
  • LoRaWAN MAC version ; 1.1.0
  • LoRaWAN Regional Parameters revision *: A
  • Max EIRP *: 0
  • JOIN(OTAA/ABO)
    Device supports OTAA: true
  • CLASS-B
    Device supports Class-B: false
  • CLASS-C
    Device supports Class-C: false
appliocations–>devices:
  • device name: MKR1300
    Device EUI: a8610************* (–>from MKR 1300)
  • Application configuration:
    Disable frame-counter validation: true
  • KEYS (OTAA):
    Network key (LoRaWAN 1.1) *: dc a5 ****************** (MSB)
    Application key (LoRaWAN 1.1) : 2a 32 *************** (MSB)
  • AKTIVATION:
    This device has not (yet) been activated.
LIVE LORAWAN FRAMES:
after a few tries I have found a solution. Although the device should support LoRa 1.1.x it only works with an older version 1.0.x.
Hi, I have the same problem, Can you explain more? Where I need to change the version?
