Hi, I flashed LoRa Gateway OS to SD and tried to boot, just get 7 flashes on the LED as if there’s no boot available. Am I dumb? I see there’s an ARM6 version of LoRaServer but I’d like the OS.
Disregard, I see server might work, OS is Rpi 3 only.
The LoRa Gateway OS image is targeting Raspberry Pi 3. With minimal changes, supporting a RPi Zero W should be possible but this is currently not high on my backlog. However, all the LoRa Gateway OS recipes are open-source so if somebody would like to give this a try and test this…
It might be as easy as just changing the MACHINE variable in the Yocto configuration to target the right machine configuration.
