LoRa Gateway setupwith ic880A-spi and RPi 3
Hi ,i would like to build a Lora Gateway using IC880A and RPi 3… Successfully connected the IC880a and RPi-3. i have 2 SEMTECH lora modules(SX1272RF1)… I would like to send some temperature data to IC880A Gateway… Please help me to do this… i’m new to LORA and trying to understand the concepts… Please help me
https://www.loraserver.io/lora-gateway-os/overview/ is the best starting point as it provides you with a ready to flash SD card image for the Raspberry Pi supporting the IC880A concentrator shield :slight_smile:
Hi, i download and used the SD card image for my Raspberry pi. and also i’m using the IC880A concentrator… Successfully login to the raspberry and created application and gateway… But, i’m not able to see any received data at raspberry pi using mosquitto_sub -v -t “gateway/#”…
Gateway shows
I have the same problem but nobody knows how to solve it here …
