Just received a LoRa hat from pi-supply and installing the Chirpstack on the Rpi4 (raspian lite OS).
The Chirpstack Srvs are running and gateway-bridge is setup and listening on port 1700.
Nov 05 16:17:15 raspberrypi chirpstack-gateway-bridge[561]: time="2020-11-05T16:17:15Z" level=info msg="starting ChirpStack Gateway Bridge" docs="https://www.chirpstack.io/gateway-bridge/" version=3.9.2
Nov 05 16:17:15 raspberrypi chirpstack-gateway-bridge[561]: time="2020-11-05T16:17:15Z" level=info msg="backend/semtechudp: starting gateway udp listener" addr="0.0.0.0:1700"
Nov 05 16:17:16 raspberrypi chirpstack-gateway-bridge[561]: time="2020-11-05T16:17:16Z" level=info msg="integration/mqtt: connected to mqtt broker"
However on ChirpStack site (https://www.chirpstack.io/gateway-bridge/gateway/) there is no information regarding integrating the LoRa hat for ChirpStack. And the missing part is the packet fwd configuration / installation.
How to set the packet fwd up (in case of pi supply LoRa hat)?
Thanks in advance
