I’ve updated the server via apt-get update & apt-get upgrade today.
The LoRa things were also automatically updated (now I have v. 0.11.0).
After the update and reset, the LoRa things were not started correctly.
I manually started mosquitto, loraserver, lora-app-server, lora-gateway-bridge but I got a few errors.
After googling around and checking log files, I’ve added
GW_SERVER_JWT_SECRET=Zysxxxxxxxxx= into /etc/default/loraserver and
JWT_SECRET=Zysxxxxxxxxx= into /etc/default/lora-app-server
After restarting services manually with systemctl, everything started to work.
I rebooted the server and the services did not start automatically.
If after reboot I manually do:
systemctl restart mosquitto
systemctl restart loraserver
systemctl restart lora-app-server
systemctl restart lora-gateway-bridge
then everything works again (log file start at Aug 01 12:19:31 LoraServer30 systemd[1]: Stopped LSB: mosquitto MQTT v3.1 message broker.).
Another interesting thing poping up in the logs: 116.31.116.49 - anyone knows what this is is?
Boot Log:
Aug 01 12:05:00 LoraServer30 systemd[1]: Reached target Login Prompts.
Aug 01 12:05:00 LoraServer30 systemd[1]: Started LoRa Gateway Bridge.
Aug 01 12:05:00 LoraServer30 systemd[1]: Started LoRa Server.
Aug 01 12:05:00 LoraServer30 systemd[1]: Started LSB: Node-RED initialisation.
Aug 01 12:05:00 LoraServer30 systemd[1]: Started Set console scheme.
Aug 01 12:05:00 LoraServer30 lora-gateway-bridge[1248]: time="2017-08-01T12:05:00+02:00" level=info msg="starting LoRa Gateway Bridge" docs="https://docs.loraserver.io/lora-gateway-bridge/" version=2.1.5
Aug 01 12:05:00 LoraServer30 lora-gateway-bridge[1248]: time="2017-08-01T12:05:00+02:00" level=info msg="backend: connecting to mqtt broker" server="tcp://localhost:1883"
Aug 01 12:05:00 LoraServer30 lora-gateway-bridge[1248]: time="2017-08-01T12:05:00+02:00" level=error msg="could not setup mqtt backend, retry in 2 seconds: Network Error : dial tcp [::1]:1883: getsockopt: connection refused"
Aug 01 12:05:00 LoraServer30 loraserver[1252]: time="2017-08-01T12:05:00+02:00" level=info msg="starting LoRa Server" band="EU_863_870" docs="https://docs.loraserver.io/" net_id=010203 version=0.20.0
Aug 01 12:05:00 LoraServer30 loraserver[1252]: time="2017-08-01T12:05:00+02:00" level=info msg="setup redis connection pool" url="redis://localhost:6379"
Aug 01 12:05:00 LoraServer30 loraserver[1252]: time="2017-08-01T12:05:00+02:00" level=info msg="connecting to postgresql"
Aug 01 12:05:00 LoraServer30 loraserver[1252]: time="2017-08-01T12:05:00+02:00" level=error msg="ping database error, will retry in 2s: pq: the database system is starting up"
Aug 01 12:05:02 LoraServer30 kernel: e1000: ens3 NIC Link is Up 1000 Mbps Full Duplex, Flow Control: RX
Aug 01 12:05:02 LoraServer30 kernel: IPv6: ADDRCONF(NETDEV_CHANGE): ens3: link becomes ready
Aug 01 12:05:02 LoraServer30 systemd[1]: Started PostgreSQL Cluster 9.5-main.
Aug 01 12:05:02 LoraServer30 systemd[1]: Starting PostgreSQL RDBMS...
Aug 01 12:05:02 LoraServer30 lora-gateway-bridge[1248]: time="2017-08-01T12:05:02+02:00" level=info msg="backend: connecting to mqtt broker" server="tcp://localhost:1883"
Aug 01 12:05:02 LoraServer30 systemd[1]: Started PostgreSQL RDBMS.
Aug 01 12:05:02 LoraServer30 lora-gateway-bridge[1248]: time="2017-08-01T12:05:02+02:00" level=error msg="could not setup mqtt backend, retry in 2 seconds: Network Error : dial tcp [::1]:1883: getsockopt: connection refused"
Aug 01 12:05:02 LoraServer30 systemd[1]: Started LoRa App Server.
Aug 01 12:05:02 LoraServer30 systemd[1]: Reached target Multi-User System.
Aug 01 12:05:02 LoraServer30 systemd[1]: Reached target Graphical Interface.
Aug 01 12:05:02 LoraServer30 loraserver[1252]: time="2017-08-01T12:05:02+02:00" level=info msg="backend/gateway: connecting to mqtt broker" server="tcp://localhost:1883"
Aug 01 12:05:02 LoraServer30 loraserver[1252]: time="2017-08-01T12:05:02+02:00" level=error msg="backend/gateway: connecting to mqtt broker failed, will retry in 2s: Network Error : dial tcp [::1]:1883: getsockopt: connection refused"
Aug 01 12:05:02 LoraServer30 systemd[1]: Starting Update UTMP about System Runlevel Changes...
Aug 01 12:05:02 LoraServer30 systemd[1]: Started Update UTMP about System Runlevel Changes.
Aug 01 12:05:02 LoraServer30 systemd[1]: Startup finished in 2.661s (kernel) + 3.682s (userspace) = 6.344s.
Aug 01 12:05:02 LoraServer30 lora-app-server[1299]: time="2017-08-01T12:05:02+02:00" level=info msg="starting LoRa App Server" docs="https://docs.loraserver.io/" version=0.11.0
Aug 01 12:05:02 LoraServer30 lora-app-server[1299]: time="2017-08-01T12:05:02+02:00" level=info msg="connecting to postgresql"
Aug 01 12:05:02 LoraServer30 lora-app-server[1299]: time="2017-08-01T12:05:02+02:00" level=info msg="setup redis connection pool"
Aug 01 12:05:02 LoraServer30 lora-app-server[1299]: time="2017-08-01T12:05:02+02:00" level=info msg="handler/mqtt: connecting to mqtt broker" server="tcp://localhost:1883"
Aug 01 12:05:02 LoraServer30 lora-app-server[1299]: time="2017-08-01T12:05:02+02:00" level=error msg="handler/mqtt: connecting to broker error, will retry in 2s: Network Error : dial tcp [::1]:1883: getsockopt: connection refused"
Aug 01 12:05:04 LoraServer30 lora-gateway-bridge[1248]: time="2017-08-01T12:05:04+02:00" level=info msg="backend: connecting to mqtt broker" server="tcp://localhost:1883"
Aug 01 12:05:04 LoraServer30 lora-gateway-bridge[1248]: time="2017-08-01T12:05:04+02:00" level=error msg="could not setup mqtt backend, retry in 2 seconds: Network Error : dial tcp [::1]:1883: getsockopt: connection refused"
Aug 01 12:19:31 LoraServer30 loraserver[1252]: time="2017-08-01T12:19:31+02:00" level=error msg="backend/gateway: connecting to mqtt broker failed, will retry in 2s: Network Error : dial tcp [::1]:1883: getsockopt: connection refused"
Aug 01 12:19:31 LoraServer30 lora-app-server[1299]: time="2017-08-01T12:19:31+02:00" level=error msg="handler/mqtt: connecting to broker error, will retry in 2s: Network Error : dial tcp [::1]:1883: getsockopt: connection refused"
Aug 01 12:19:31 LoraServer30 sudo[1537]: uros : TTY=pts/0 ; PWD=/home/uros/scripts ; USER=root ; COMMAND=./restartLora.sh
Aug 01 12:19:31 LoraServer30 sudo[1537]: pam_unix(sudo:session): session opened for user root by uros(uid=0)
Aug 01 12:19:31 LoraServer30 systemd[1]: Stopping LSB: mosquitto MQTT v3.1 message broker...
Aug 01 12:19:31 LoraServer30 lora-gateway-bridge[1248]: time="2017-08-01T12:19:31+02:00" level=info msg="backend: connecting to mqtt broker" server="tcp://localhost:1883"
Aug 01 12:19:31 LoraServer30 mosquitto[1541]: * Stopping network daemon: mosquitto
Aug 01 12:19:31 LoraServer30 mosquitto[1541]: start-stop-daemon: warning: failed to kill 1213: No such process
Aug 01 12:19:31 LoraServer30 mosquitto[1541]: ...done.
Aug 01 12:19:31 LoraServer30 lora-gateway-bridge[1248]: time="2017-08-01T12:19:31+02:00" level=error msg="could not setup mqtt backend, retry in 2 seconds: Network Error : dial tcp [::1]:1883: getsockopt: connection refused"
Aug 01 12:19:31 LoraServer30 systemd[1]: Starting LSB: mosquitto MQTT v3.1 message broker...
Aug 01 12:19:31 LoraServer30 mosquitto[1550]: * Starting network daemon: mosquitto
Aug 01 12:19:31 LoraServer30 mosquitto[1550]: ...done.
Aug 01 12:19:31 LoraServer30 systemd[1]: Started LSB: mosquitto MQTT v3.1 message broker.
Aug 01 12:19:32 LoraServer30 systemd[1]: Stopping LoRa Server...
Aug 01 12:19:32 LoraServer30 systemd[1]: Stopped LoRa Server.
Aug 01 12:19:32 LoraServer30 systemd[1]: Started LoRa Server.
Aug 01 12:19:32 LoraServer30 loraserver[1568]: time="2017-08-01T12:19:32+02:00" level=info msg="starting LoRa Server" band="EU_863_870" docs="https://docs.loraserver.io/" net_id=010203 version=0.20.0
Aug 01 12:19:32 LoraServer30 loraserver[1568]: time="2017-08-01T12:19:32+02:00" level=info msg="setup redis connection pool" url="redis://localhost:6379"
Aug 01 12:19:32 LoraServer30 loraserver[1568]: time="2017-08-01T12:19:32+02:00" level=info msg="connecting to postgresql"
Aug 01 12:19:32 LoraServer30 loraserver[1568]: time="2017-08-01T12:19:32+02:00" level=info msg="backend/gateway: connecting to mqtt broker" server="tcp://localhost:1883"
Aug 01 12:19:32 LoraServer30 loraserver[1568]: time="2017-08-01T12:19:32+02:00" level=info msg="connecting to application-server" ca-cert= server="127.0.0.1:8001" tls-cert= tls-key=
Aug 01 12:19:32 LoraServer30 loraserver[1568]: time="2017-08-01T12:19:32+02:00" level=info msg="backend/gateway: connected to mqtt server"
Aug 01 12:19:32 LoraServer30 loraserver[1568]: time="2017-08-01T12:19:32+02:00" level=info msg="backend/gateway: subscribing to rx topic" topic="gateway/+/rx"
Aug 01 12:19:32 LoraServer30 loraserver[1568]: time="2017-08-01T12:19:32+02:00" level=info msg="backend/gateway: subscribing to stats topic" topic="gateway/+/stats"
Aug 01 12:19:32 LoraServer30 loraserver[1568]: time="2017-08-01T12:19:32+02:00" level=info msg="no network-controller configured"
Aug 01 12:19:32 LoraServer30 loraserver[1568]: time="2017-08-01T12:19:32+02:00" level=info msg="grpc: addrConn.resetTransport failed to create client transport: connection error: desc = "transport: Error while dialing dial tcp 127.0.0.1:
Aug 01 12:19:32 LoraServer30 loraserver[1568]: time="2017-08-01T12:19:32+02:00" level=info msg="migrated node-sessions to new format" errors=0 migrated=0
Aug 01 12:19:32 LoraServer30 loraserver[1568]: time="2017-08-01T12:19:32+02:00" level=info msg="applying database migrations"
Aug 01 12:19:32 LoraServer30 loraserver[1568]: time="2017-08-01T12:19:32+02:00" level=info msg="migrations applied" count=0
Aug 01 12:19:32 LoraServer30 loraserver[1568]: time="2017-08-01T12:19:32+02:00" level=info msg="starting api server" bind="0.0.0.0:8000" ca-cert= tls-cert= tls-key=
Aug 01 12:19:32 LoraServer30 loraserver[1568]: time="2017-08-01T12:19:32+02:00" level=info msg="starting gateway api server" bind="0.0.0.0:8002" ca-cert= tls-cert= tls-key=
Aug 01 12:19:33 LoraServer30 lora-app-server[1299]: time="2017-08-01T12:19:33+02:00" level=info msg="connecting to network-server api" ca-cert= server="127.0.0.1:8000" tls-cert= tls-key=
Aug 01 12:19:33 LoraServer30 lora-app-server[1299]: time="2017-08-01T12:19:33+02:00" level=info msg="handler/mqtt: connected to mqtt broker"
Aug 01 12:19:33 LoraServer30 lora-app-server[1299]: time="2017-08-01T12:19:33+02:00" level=info msg="handler/mqtt: subscribling to tx topic" topic="application/+/node/+/tx"
Aug 01 12:19:33 LoraServer30 lora-app-server[1299]: time="2017-08-01T12:19:33+02:00" level=info msg="applying database migrations"
Aug 01 12:19:33 LoraServer30 lora-app-server[1299]: time="2017-08-01T12:19:33+02:00" level=info msg="migrations applied" count=0
Aug 01 12:19:33 LoraServer30 lora-app-server[1299]: time="2017-08-01T12:19:33+02:00" level=info msg="starting application-server api" bind="localhost:8001" ca-cert= tls-cert= tls-key=
Aug 01 12:19:33 LoraServer30 lora-app-server[1299]: time="2017-08-01T12:19:33+02:00" level=info msg="starting client api server" bind="0.0.0.0:8080" tls-cert="/etc/lora-app-server/certs/http.pem" tls-key="/etc/lora-app-server/certs/http-
Aug 01 12:19:33 LoraServer30 lora-app-server[1299]: time="2017-08-01T12:19:33+02:00" level=info msg="registering rest api handler and documentation endpoint" path="/api"
Aug 01 12:19:33 LoraServer30 lora-gateway-bridge[1248]: time="2017-08-01T12:19:33+02:00" level=info msg="backend: connecting to mqtt broker" server="tcp://localhost:1883"
Aug 01 12:19:33 LoraServer30 lora-gateway-bridge[1248]: time="2017-08-01T12:19:33+02:00" level=info msg="gateway: starting gateway udp listener" addr=0.0.0.0:1700
Aug 01 12:19:33 LoraServer30 lora-gateway-bridge[1248]: time="2017-08-01T12:19:33+02:00" level=info msg="backend: connected to mqtt broker"
Aug 01 12:19:33 LoraServer30 systemd[1]: Stopping LoRa App Server...
Aug 01 12:19:33 LoraServer30 lora-app-server[1299]: time="2017-08-01T12:19:33+02:00" level=info msg="signal received" signal=terminated
Aug 01 12:19:33 LoraServer30 lora-app-server[1299]: time="2017-08-01T12:19:33+02:00" level=warning msg="stopping lora-app-server"
Aug 01 12:19:33 LoraServer30 systemd[1]: Stopped LoRa App Server.
Aug 01 12:19:33 LoraServer30 loraserver[1568]: time="2017-08-01T12:19:33+02:00" level=info msg="grpc: addrConn.resetTransport failed to create client transport: connection error: desc = "transport: Error while dialing dial tcp 127.0.0.1:
Aug 01 12:19:33 LoraServer30 systemd[1]: Started LoRa App Server.
Aug 01 12:19:33 LoraServer30 lora-app-server[1583]: time="2017-08-01T12:19:33+02:00" level=info msg="starting LoRa App Server" docs="https://docs.loraserver.io/" version=0.11.0
Aug 01 12:19:33 LoraServer30 lora-app-server[1583]: time="2017-08-01T12:19:33+02:00" level=info msg="connecting to postgresql"
Aug 01 12:19:33 LoraServer30 lora-app-server[1583]: time="2017-08-01T12:19:33+02:00" level=info msg="setup redis connection pool"
Aug 01 12:19:33 LoraServer30 lora-app-server[1583]: time="2017-08-01T12:19:33+02:00" level=info msg="handler/mqtt: connecting to mqtt broker" server="tcp://localhost:1883"
Aug 01 12:19:33 LoraServer30 lora-app-server[1583]: time="2017-08-01T12:19:33+02:00" level=info msg="handler/mqtt: connected to mqtt broker"
Aug 01 12:19:33 LoraServer30 lora-app-server[1583]: time="2017-08-01T12:19:33+02:00" level=info msg="handler/mqtt: subscribling to tx topic" topic="application/+/node/+/tx"
Aug 01 12:19:33 LoraServer30 lora-app-server[1583]: time="2017-08-01T12:19:33+02:00" level=info msg="connecting to network-server api" ca-cert= server="127.0.0.1:8000" tls-cert= tls-key=
Aug 01 12:19:33 LoraServer30 lora-app-server[1583]: time="2017-08-01T12:19:33+02:00" level=info msg="applying database migrations"
Aug 01 12:19:33 LoraServer30 lora-app-server[1583]: time="2017-08-01T12:19:33+02:00" level=info msg="migrations applied" count=0
Aug 01 12:19:33 LoraServer30 lora-app-server[1583]: time="2017-08-01T12:19:33+02:00" level=info msg="starting application-server api" bind="localhost:8001" ca-cert= tls-cert= tls-key=
Aug 01 12:19:33 LoraServer30 lora-app-server[1583]: time="2017-08-01T12:19:33+02:00" level=info msg="starting client api server" bind="0.0.0.0:8080" tls-cert="/etc/lora-app-server/certs/http.pem" tls-key="/etc/lora-app-server/certs/http-
Aug 01 12:19:33 LoraServer30 lora-app-server[1583]: time="2017-08-01T12:19:33+02:00" level=info msg="registering rest api handler and documentation endpoint" path="/api"
Aug 01 12:19:34 LoraServer30 systemd[1]: Stopping LoRa Gateway Bridge...
Aug 01 12:19:34 LoraServer30 lora-gateway-bridge[1248]: time="2017-08-01T12:19:34+02:00" level=info msg="signal received" signal=terminated
Aug 01 12:19:34 LoraServer30 lora-gateway-bridge[1248]: time="2017-08-01T12:19:34+02:00" level=warning msg="shutting down server"
Aug 01 12:19:34 LoraServer30 lora-gateway-bridge[1248]: time="2017-08-01T12:19:34+02:00" level=info msg="gateway: closing gateway backend"
Aug 01 12:19:34 LoraServer30 lora-gateway-bridge[1248]: time="2017-08-01T12:19:34+02:00" level=info msg="gateway: handling last packets"
Aug 01 12:19:34 LoraServer30 systemd[1]: Stopped LoRa Gateway Bridge.
Aug 01 12:19:34 LoraServer30 systemd[1]: Started LoRa Gateway Bridge.
Aug 01 12:19:34 LoraServer30 lora-gateway-bridge[1597]: time="2017-08-01T12:19:34+02:00" level=info msg="starting LoRa Gateway Bridge" docs="https://docs.loraserver.io/lora-gateway-bridge/" version=2.1.5
Aug 01 12:19:34 LoraServer30 lora-gateway-bridge[1597]: time="2017-08-01T12:19:34+02:00" level=info msg="backend: connecting to mqtt broker" server="tcp://localhost:1883"
Aug 01 12:19:34 LoraServer30 lora-gateway-bridge[1597]: time="2017-08-01T12:19:34+02:00" level=info msg="gateway: starting gateway udp listener" addr=0.0.0.0:1700
Aug 01 12:19:34 LoraServer30 lora-gateway-bridge[1597]: time="2017-08-01T12:19:34+02:00" level=info msg="backend: connected to mqtt broker"
Aug 01 12:19:34 LoraServer30 lora-gateway-bridge[1597]: time="2017-08-01T12:19:34+02:00" level=info msg="gateway: received udp packet from gateway" addr=10.0.3.103:58684 protocol_version=2 type=PullData
Aug 01 12:19:34 LoraServer30 lora-gateway-bridge[1597]: time="2017-08-01T12:19:34+02:00" level=info msg="backend: subscribing to topic" topic="gateway/7076fffffe0200c0/tx"
Aug 01 12:19:34 LoraServer30 lora-gateway-bridge[1597]: time="2017-08-01T12:19:34+02:00" level=info msg="gateway: sending udp packet to gateway" addr=10.0.3.103:58684 protocol_version=2 type=PullACK
Aug 01 12:19:35 LoraServer30 sudo[1537]: pam_unix(sudo:session): session closed for user root
Aug 01 12:19:38 LoraServer30 lora-gateway-bridge[1597]: time="2017-08-01T12:19:38+02:00" level=info msg="gateway: received udp packet from gateway" addr=10.0.3.103:46586 protocol_version=2 type=PushData
Aug 01 12:19:38 LoraServer30 lora-gateway-bridge[1597]: time="2017-08-01T12:19:38+02:00" level=info msg="gateway: stat packet received" addr=10.0.3.103:46586 mac=7076fffffe0200c0
Aug 01 12:19:38 LoraServer30 lora-gateway-bridge[1597]: time="2017-08-01T12:19:38+02:00" level=info msg="backend: publishing packet" topic="gateway/7076fffffe0200c0/stats"
Aug 01 12:19:38 LoraServer30 lora-gateway-bridge[1597]: time="2017-08-01T12:19:38+02:00" level=info msg="gateway: sending udp packet to gateway" addr=10.0.3.103:46586 protocol_version=2 type=PushACK
Aug 01 12:19:38 LoraServer30 loraserver[1568]: time="2017-08-01T12:19:38+02:00" level=info msg="backend/gateway: gateway stats packet received" mac=7076fffffe0200c0
Aug 01 12:19:38 LoraServer30 loraserver[1568]: time="2017-08-01T12:19:38+02:00" level=info msg="gateway updated" mac=7076fffffe0200c0
Aug 01 12:19:45 LoraServer30 lora-gateway-bridge[1597]: time="2017-08-01T12:19:45+02:00" level=info msg="gateway: received udp packet from gateway" addr=10.0.3.103:58684 protocol_version=2 type=PullData
Aug 01 12:19:45 LoraServer30 lora-gateway-bridge[1597]: time="2017-08-01T12:19:45+02:00" level=info msg="gateway: sending udp packet to gateway" addr=10.0.3.103:58684 protocol_version=2 type=PullACK
Aug 01 12:19:55 LoraServer30 lora-gateway-bridge[1597]: time="2017-08-01T12:19:55+02:00" level=info msg="gateway: received udp packet from gateway" addr=10.0.3.103:58684 protocol_version=2 type=PullData
Aug 01 12:19:55 LoraServer30 lora-gateway-bridge[1597]: time="2017-08-01T12:19:55+02:00" level=info msg="gateway: sending udp packet to gateway" addr=10.0.3.103:58684 protocol_version=2 type=PullACK
Aug 01 12:20:00 LoraServer30 systemd[1]: Starting Cleanup of Temporary Directories...
Aug 01 12:20:00 LoraServer30 systemd-tmpfiles[1614]: [/usr/lib/tmpfiles.d/var.conf:14] Duplicate line for path "/var/log", ignoring.
Aug 01 12:20:00 LoraServer30 systemd[1]: Started Cleanup of Temporary Directories.
Aug 01 12:20:05 LoraServer30 lora-gateway-bridge[1597]: time="2017-08-01T12:20:05+02:00" level=info msg="gateway: received udp packet from gateway" addr=10.0.3.103:58684 protocol_version=2 type=PullData
Aug 01 12:20:05 LoraServer30 lora-gateway-bridge[1597]: time="2017-08-01T12:20:05+02:00" level=info msg="gateway: sending udp packet to gateway" addr=10.0.3.103:58684 protocol_version=2 type=PullACK
Aug 01 12:20:06 LoraServer30 sshd[1619]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=116.31.116.49 user=root
Aug 01 12:20:08 LoraServer30 sshd[1619]: Failed password for root from 116.31.116.49 port 37231 ssh2
Aug 01 12:20:08 LoraServer30 lora-gateway-bridge[1597]: time="2017-08-01T12:20:08+02:00" level=info msg="gateway: received udp packet from gateway" addr=10.0.3.103:46586 protocol_version=2 type=PushData
Aug 01 12:20:08 LoraServer30 lora-gateway-bridge[1597]: time="2017-08-01T12:20:08+02:00" level=info msg="gateway: stat packet received" addr=10.0.3.103:46586 mac=7076fffffe0200c0
Aug 01 12:20:08 LoraServer30 lora-gateway-bridge[1597]: time="2017-08-01T12:20:08+02:00" level=info msg="backend: publishing packet" topic="gateway/7076fffffe0200c0/stats"
Aug 01 12:20:08 LoraServer30 lora-gateway-bridge[1597]: time="2017-08-01T12:20:08+02:00" level=info msg="gateway: sending udp packet to gateway" addr=10.0.3.103:46586 protocol_version=2 type=PushACK
Aug 01 12:20:08 LoraServer30 loraserver[1568]: time="2017-08-01T12:20:08+02:00" level=info msg="backend/gateway: gateway stats packet received" mac=7076fffffe0200c0
Aug 01 12:20:08 LoraServer30 loraserver[1568]: time="2017-08-01T12:20:08+02:00" level=info msg="gateway updated" mac=7076fffffe0200c0
Aug 01 12:20:10 LoraServer30 sshd[1619]: Failed password for root from 116.31.116.49 port 37231 ssh2
Aug 01 12:20:12 LoraServer30 sshd[1619]: Failed password for root from 116.31.116.49 port 37231 ssh2
Aug 01 12:20:12 LoraServer30 sshd[1619]: Received disconnect from 116.31.116.49 port 37231:11: [preauth]
Aug 01 12:20:12 LoraServer30 sshd[1619]: Disconnected from 116.31.116.49 port 37231 [preauth]
Aug 01 12:20:12 LoraServer30 sshd[1619]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=116.31.116.49 user=root
Aug 01 12:20:15 LoraServer30 lora-gateway-bridge[1597]: time="2017-08-01T12:20:15+02:00" level=info msg="gateway: received udp packet from gateway" addr=10.0.3.103:58684 protocol_version=2 type=PullData
Aug 01 12:20:15 LoraServer30 lora-gateway-bridge[1597]: time="2017-08-01T12:20:15+02:00" level=info msg="gateway: sending udp packet to gateway" addr=10.0.3.103:58684 protocol_version=2 type=PullACK
Aug 01 12:20:20 LoraServer30 sudo[1621]: uros : TTY=pts/0 ; PWD=/home/uros/scripts ; USER=root ; COMMAND=/bin/journalctl -b
Aug 01 12:20:20 LoraServer30 sudo[1621]: pam_unix(sudo:session): session opened for user root by uros(uid=0)
Aug 01 12:20:25 LoraServer30 lora-gateway-bridge[1597]: time="2017-08-01T12:20:25+02:00" level=info msg="gateway: received udp packet from gateway" addr=10.0.3.103:58684 protocol_version=2 type=PullData
Aug 01 12:20:25 LoraServer30 lora-gateway-bridge[1597]: time="2017-08-01T12:20:25+02:00" level=info msg="gateway: sending udp packet to gateway" addr=10.0.3.103:58684 protocol_version=2 type=PullACK
