I have installed LoRaServer according to instructions in the ‘loraserver.io’.
The Loraserver work properly.
But It looks like the LoRaServer can not connect with the Gateway.
I have configured the MQTT user-password and postgresql user-password.
I have filled the GatewayID \DevEUI\Appkey in the LoraServer .
I have filled the IP of Loraserver and upstream/downstream port in the Gateway.
The Gateway is set to "Packet Forwarder"
Could you give me some advice in order to let the Loraserver to connect with the Gateway ?
Are there any commands to debug ?
if the Gateway forward all the received data from node ?
if there are some commands to show all the received data in the loraserver?
