Hi!
I’m trying to install LoRaServer on a Dell running Ubuntu Server 18.04 and when I start LoRaServer, it displays this:
Oct 29 14:40:48 CMTJM42 loraserver[3785]: time=“2018-10-29T14:40:48Z” level=info msg=“connecting to postgresql”
Oct 29 14:40:48 CMTJM42 loraserver[3785]: time=“2018-10-29T14:40:48Z” level=error msg=“ping database error, will retry in 2s: pq: password authentication failed for user “loraserver””
And displays the same error (switching the user) for Lora Gateway Bridge and Lora App Server.
I think the error is clear, there is a password database problem, but I’m starting on this and don’t know what to do.
I have read all the posts about this topic, and made the modifications on:
loraserver.toml
POSTGRES_DSN="postgres://loraserver_ns:dbpassword@localhost/loraserver_ns?sslmode=disable"
lora-gateway-bridge.toml
POSTGRES_DSN="postgres://loraserver_as:dbpassword@localhost/loraserver_as?sslmode=disable"
And made the config postgre database where I modify the listen_addresses and add 2 lines on the end of hba.conf.
But the problem is still the same…
root@CMTJM42:/# sudo journalctl -f -n 10 -u loraserver
-- Logs begin at Mon 2018-10-29 10:36:02 UTC. --
Nov 06 10:37:21 CMTJM42 loraserver[1167]: time="2018-11-06T10:37:21Z" level=error msg="ping database error, will retry in 2s: pq: password authentication failed for user \"loraserver\""
root@CMTJM42:/# lora-gateway-bridge INFO[0000] starting LoRa Gateway Bridge docs="https://www.loraserver.io/lora-gateway-bridge/" version=2.6.1 INFO[0000] backend: set max reconnect interval: 10m0s INFO[0000] backend: TLS config is empty INFO[0000] backend: connecting to mqtt broker server="tcp://127.0.0.1:1883" INFO[0000] gateway: starting gateway udp listener addr="0.0.0.0:1700" FATA[0000] could not setup gateway backend: listen udp 0.0.0.0:1700: bind: address already in use root@CMTJM42:/# lora-app-server INFO[0000] starting LoRa App Server docs="https://www.loraserver.io/" version=2.3.0 INFO[0000] connecting to postgresql ERRO[0000] ping database error, will retry in 2s: pq: password authentication failed for user "root" ERRO[0002] ping database error, will retry in 2s: pq: password authentication failed for user "root" ERRO[0004] ping database error, will retry in 2s: pq: password authentication failed for user "root" ^C root@CMTJM42:/# loraserver FATA[0000] read configuration file error error="While parsing config: (221, 51): unexpected token"
When I try to start LoRa Server from the CLI:
root@CMTJM42:/# sudo -u loraserver loraserver -c /etc/loraserver/loraserver.toml FATA[0000] error loading config file config=/etc/loraserver/loraserver.toml error="While parsing config: (221, 51): unexpected token"
Thanks in advance ![]()
