LoraWan Frames come with 5 min delay when using NGINX as proxy
Greetings,
I noticed a strange change right after I configured the nginx for https > all the frames from different nodes are coming with ~5 min delay.
I am using Chirpstack v4.
Tried different Internet provider, different GWs, nodes. Same.
Is that an expected behavior? Sorry for generic question, maybe anyone has faced it also, before I dig deeper?
Thanks
Short feedback, I have disabled ufw and nginx and now messages are coming immediately like before (but no https).
So confirmed, the delay is a side effect of https/nginx config. I remember there was some comment on Chirpstack forum about API feed delay after enabling https? (can’t recall where it was exactly). Perhaps this is common for the front-end as well?
Please see this NGINX proxy example:
Thanks brocaar,
You have pointed me in right direction.
I have replaced below lines in /etc/nginx/sites-available/default config file
Before:
WebSocket configuration
location ~ ^/api/(gateways|devices)/(\w+)/(frames|events)$ {
proxy_pass http://localhost:8080/api/$1/$2/$3;
proxy_http_version 1.1;
proxy_set_header Upgrade $http_upgrade;
proxy_set_header Connection ā€œUpgradeā€;
proxy_read_timeout 86400s;
proxy_send_timeout 86400s;
After
location ^~ /api {
grpc_pass grpc://localhost:8080;
Restarted nginx service and now I see the lorawan frames immediately once uplink in sent from the node (before this change, messages were coming all at once with 5 min delay).
Perhaps it was due to proxy read/send timeout…not sure. Anyway, it looks ok now.
Thanks a lot
Hi, and what if I have setup that chirpstack is served from subpath like:
www.domain.com/chirpstack
How can I solve this situation?
location ^~ /api {
does not seem to work, even
location ^~ /api/chirpstack {
is not working.
any advice will be blessing
Kind regards
Should be /chirpstack/api?
