I have a CentOS instance running a modified Docker image with ChirpStack and I want to use the LoRaWAN live frames, but I got the following error:
The Docker image runs behind an nginx with the following configuraion:
version: "3"
services:
chirpstack-network-server:
image: chirpstack/chirpstack-network-server:3
volumes:
- ./configuration/chirpstack-network-server:/etc/chirpstack-network-server
depends_on:
- postgresql
- mosquitto
chirpstack-application-server:
image: chirpstack/chirpstack-application-server:3
ports:
- 8102:8080
volumes:
- ./configuration/chirpstack-application-server:/etc/chirpstack-application-server
depends_on:
- chirpstack-network-server
chirpstack-gateway-bridge:
image: chirpstack/chirpstack-gateway-bridge:3
ports:
- 11700:1700/udp
volumes:
depends_on:
- mosquitto
postgresql:
image: postgres:9.6-alpine
environment:
- POSTGRES_PASSWORD=root
volumes:
redis:
image: redis:5-alpine
volumes:
- redisdata:/data
mosquitto:
image: eclipse-mosquitto:2
ports:
- 11883:1883
volumes:
- ./configuration/eclipse-mosquitto/mosquitto.conf:/mosquitto/config/mosquitto.conf
volumes:
postgresqldata:
redisdata:
I changed some ports because the default ports are used by some other web applications. How can I fix this issue?
Thank you
