Is it possible to use IP based protocol in LORA Module to send point to point communication ?
I am using Intel Edison to make monitoring system with Current Receivers which monitor the reading of linear path of the sensors (connected in series with external voltage of 24 V) with wireless module and share the reading to user with secured path
Your Suggestions will be very helpful
It is possible to make the Lora Module to work as IP based protocol but you have to read it out the manual which will help you to configure IP in your LORA WAN and at the same time you can also assign the IP to the functions you are interfacing with LORA WAN
