Hi Have anyone use this setup before
@Cobus I have tried that without node-red.
I wanted to share what I did in case it might be of some use to you. Make sure your libelium plug and play complies with lora.
Change the multitech to packet forwarder.
On multitech “LoraWan -> network setting” change the server address and port number according to this lora server.
On lora-app-server, configure your gateway.
Then on the lora-app-server , you need to configure your libelium device using the deveui, devaddr ,appkey, NwkSKey , AppSKey if it is in ABP mode else use deveui and appkey in OTAA mode.
You should be being the live lorawan frames for the device.
cheers
