Hello Everyone,
I was using V3 as a serveur receiving roaming call from another server.
So the Roaming API:8181 was configured and used.
After upgrading/migrating to V4, i no more have access to Roaming API:
Connection refused!!!
Hello Everyone,
@brocaar Any help would be very appreciated, i know that you are very busy. But your answear will determine if i have to rollback or not :-/
ChirpStack v4 does support the passive-roaming API. The connection refused sounds like either a misconfiguration or network configuration issue (e.g. firewall).
For those who are facing the same issue.
The migration seems not transfering correctly the V3 Roaming conf to the V4 conf.
use the Backend interfaces instead of Roaming to bind the correct interface:
[backend_interfaces]
#interface:port to bind the Backend Interfaces API to. NEW V4 CONF
#Note: this interface is used both for passive-roaming and when
#integrating with Join Servers that implement the async interface.
bind=“0.0.0.0:8181”
#CA certificate (path).
ca_cert="/…/certs/ca/ca.pem"
#TLS certificate (path).
tls_cert="/…/certs/chirpstack-network-server/roaming/000000/server/chirpstack-network-server-roaming-000000-server.pem"
#TLS key (path).
tls_key="/…/certs/chirpstack-network-server/roaming/000000/server/chirpstack-network-server-roaming-000000-server-key.pem"
hello All,
After a success on Ubuntu to implement V4 with roaming (V3 Certificates worked perfectly).
I implement the docker version of Chirpstack V4, but unfortunately, no way to do Roaming either on 8080 & 8181 port
on 8080 i have an http 200 ok but no PRstans like this example:
“ProtocolVersion”: “1.0”,
“SenderID”: “000000”,
“ReceiverID”: “000001”,
“TransactionID”: 140500,
“MessageType”: “PRStartAns”,
“Result”: {
“ResultCode”: “UnknownDevAddr”,
“Description”: “Object does not exist (id: xxxxxxxx)”
On port 8181, i have the error “Error: connect ECONNREFUSED X.X.X.X: 8181”
On my Toml side:
bind=“0.0.0.0:8181”
[roaming]
resolve_netid_domain_suffix=".netids.lora-alliance.org"
[[roaming.servers]]
net_id=“000001”
async_timeout="0s"
#passive_roaming=true
passive_roaming_lifetime=“0s”
my docker compose is like the example: Do i have to add the port 8181? i did it (Chirpstack services) but did not worked.
version: “3”
services:
chirpstack:
image: chirpstack/chirpstack:4.1.1
command: -c /etc/chirpstack
restart: unless-stopped
volumes:
- ./lorawan-devices:/opt/lorawan-devices
depends_on:
- postgres
- mosquitto
- redis
environment:
- MQTT_BROKER_HOST=mosquitto
- REDIS_HOST=redis
- POSTGRESQL_HOST=postgres
ports:
- 8080:8080
chirpstack-gateway-bridge-eu868:
image: chirpstack/chirpstack-gateway-bridge:4.0.3
ports:
- 1700:1700/udp
volumes:
depends_on:
- mosquitto
chirpstack-rest-api:
image: chirpstack/chirpstack-rest-api:4.1.1
command: --server chirpstack:8080 --bind 0.0.0.0:8090 --insecure
ports:
- 8090:8090
depends_on:
- chirpstack
postgres:
image: postgres:14-alpine
volumes:
environment:
- POSTGRES_PASSWORD=root
redis:
image: redis:7-alpine
volumes:
- redisdata:/data
mosquitto:
image: eclipse-mosquitto:2
ports:
- 1883:1883
volumes:
- ./configuration/mosquitto/mosquitto.conf:/mosquitto/config/mosquitto.conf
volumes:
postgresqldata:
redisdata:
