has anyone flashed the LoRa Gateway OS into the NAND Partition?
BR
fibra
BR
fibra
Currently this is not (yet) supported. It is not possible to simply flash the sdcard image into the NAND flash.
@brocaar
I have some solid experience flashing and customizing Lorix gateways and I’m working with Yannick from Lorix and I already ported other LoRa Server on Lorix and today I would like to add chirpstack
I really would like to have chirpstack running on flash and I have 2 options :
I can spend some time on it, so let me know, and if you have better idea, just let me know.
Charles
That would be great!
I think your first approach would be best (all components on NAND and writing data to SD Card). I would write the PostgreSQL and Redis data to the SD Card.
This repo contains all the ChirpStack recipes + a “firstbootinit” script which initializes the PostgreSQL database on first boot: https://github.com/brocaar/chirpstack-gateway-os.
Thanks,
As soon has I got more time I’ll check on Redis and Postgres on how to relocate default database path, should be straightforward.
This might be helpful:
dbfilename)An other approach is creating a symlink.
