I tried upgrading from Gateway OS 4.2.0 to 4.3.2, and again I the ChirpStack Restore command failed (see restore log below).
Steps:
- Currently running 4.2.0 with tenant, API keys, device profiles, applications…
- Backup my Postgres and Redis databases per 4.3.0 Changelog instructions.
- Download the 4.3.2 Sysupgrade image for Raspberry Pi 4B (my RAK7248)
- Flash the Sysupgrade image using OpenWrt web interface
- Run the ChirpStack Restore command
‘/opt/chirpstack/restore.sh’
Restore PostgreSQL database
Restore Redis database
pg_restore: error: could not execute query: ERROR: relation “__diesel_schema_migrations” already exists
Command was: CREATE TABLE public.__diesel_schema_migrations (
version character varying(50) NOT NULL,
run_on timestamp without time zone DEFAULT CURRENT_TIMESTAMP NOT NULL
pg_restore: error: could not execute query: ERROR: relation “api_key” already exists
Command was: CREATE TABLE public.api_key (
id uuid NOT NULL,
created_at timestamp with time zone NOT NULL,
name character varying(100) NOT NULL,
is_admin boolean NOT NULL,
tenant_id uuid
pg_restore: error: could not execute query: ERROR: relation “application” already exists
Command was: CREATE TABLE public.application (
id uuid NOT NULL,
tenant_id uuid NOT NULL,
updated_at timestamp with time zone NOT NULL,
description text NOT NULL,
mqtt_tls_cert bytea,
tags jsonb NOT NULL
pg_restore: error: could not execute query: ERROR: relation “application_integration” already exists
Command was: CREATE TABLE public.application_integration (
application_id uuid NOT NULL,
kind character varying(20) NOT NULL,
configuration jsonb NOT NULL
pg_restore: error: could not execute query: ERROR: relation “device” already exists
Command was: CREATE TABLE public.device (
dev_eui bytea NOT NULL,
device_profile_id uuid NOT NULL,
last_seen_at timestamp with time zone,
scheduler_run_after timestamp with time zone,
external_power_source boolean NOT NULL,
battery_level numeric(5,2),
margin integer,
dr smallint,
latitude double precision,
longitude double precision,
altitude real,
dev_addr bytea,
enabled_class character(1) NOT NULL,
skip_fcnt_check boolean NOT NULL,
is_disabled boolean NOT NULL,
tags jsonb NOT NULL,
variables jsonb NOT NULL,
join_eui bytea NOT NULL
pg_restore: error: could not execute query: ERROR: relation “device_keys” already exists
Command was: CREATE TABLE public.device_keys (
nwk_key bytea NOT NULL,
app_key bytea NOT NULL,
dev_nonces integer NOT NULL,
join_nonce integer NOT NULL
pg_restore: error: could not execute query: ERROR: relation “device_profile” already exists
Command was: CREATE TABLE public.device_profile (
id uuid NOT NULL,
region character varying(10) NOT NULL,
mac_version character varying(10) NOT NULL,
reg_params_revision character varying(20) NOT NULL,
adr_algorithm_id character varying(100) NOT NULL,
payload_codec_runtime character varying(20) NOT NULL,
uplink_interval integer NOT NULL,
device_status_req_interval integer NOT NULL,
supports_otaa boolean NOT NULL,
supports_class_b boolean NOT NULL,
supports_class_c boolean NOT NULL,
class_b_timeout integer NOT NULL,
class_b_ping_slot_nb_k integer NOT NULL,
class_b_ping_slot_dr smallint NOT NULL,
class_b_ping_slot_freq bigint NOT NULL,
class_c_timeout integer NOT NULL,
abp_rx1_delay smallint NOT NULL,
abp_rx1_dr_offset smallint NOT NULL,
abp_rx2_dr smallint NOT NULL,
abp_rx2_freq bigint NOT NULL,
payload_codec_script text NOT NULL,
flush_queue_on_activate boolean NOT NULL,
measurements jsonb NOT NULL,
auto_detect_measurements boolean NOT NULL,
region_config_id character varying(100),
is_relay boolean NOT NULL,
is_relay_ed boolean NOT NULL,
relay_ed_relay_only boolean NOT NULL,
relay_enabled boolean NOT NULL,
relay_cad_periodicity smallint NOT NULL,
relay_default_channel_index smallint NOT NULL,
relay_second_channel_freq bigint NOT NULL,
relay_second_channel_dr smallint NOT NULL,
relay_second_channel_ack_offset smallint NOT NULL,
relay_ed_activation_mode smallint NOT NULL,
relay_ed_smart_enable_level smallint NOT NULL,
relay_ed_back_off smallint NOT NULL,
relay_ed_uplink_limit_bucket_size smallint NOT NULL,
relay_ed_uplink_limit_reload_rate smallint NOT NULL,
relay_join_req_limit_reload_rate smallint NOT NULL,
relay_notify_limit_reload_rate smallint NOT NULL,
relay_global_uplink_limit_reload_rate smallint NOT NULL,
relay_overall_limit_reload_rate smallint NOT NULL,
relay_join_req_limit_bucket_size smallint NOT NULL,
relay_notify_limit_bucket_size smallint NOT NULL,
relay_global_uplink_limit_bucket_size smallint NOT NULL,
relay_overall_limit_bucket_size smallint NOT NULL,
allow_roaming boolean NOT NULL
pg_restore: error: could not execute query: ERROR: relation “device_profile_template” already exists
Command was: CREATE TABLE public.device_profile_template (
id text NOT NULL,
vendor character varying(100) NOT NULL,
firmware character varying(100) NOT NULL,
pg_restore: error: could not execute query: ERROR: relation “device_queue_item” already exists
Command was: CREATE TABLE public.device_queue_item (
id uuid NOT NULL,
f_port smallint NOT NULL,
confirmed boolean NOT NULL,
data bytea NOT NULL,
is_pending boolean NOT NULL,
f_cnt_down bigint,
timeout_after timestamp with time zone,
is_encrypted boolean NOT NULL
pg_restore: error: could not execute query: ERROR: relation “gateway” already exists
Command was: CREATE TABLE public.gateway (
gateway_id bytea NOT NULL,
latitude double precision NOT NULL,
longitude double precision NOT NULL,
altitude real NOT NULL,
stats_interval_secs integer NOT NULL,
tls_certificate bytea,
properties jsonb NOT NULL
pg_restore: error: could not execute query: ERROR: relation “multicast_group” already exists
Command was: CREATE TABLE public.multicast_group (
id uuid NOT NULL,
mc_addr bytea NOT NULL,
mc_nwk_s_key bytea NOT NULL,
mc_app_s_key bytea NOT NULL,
f_cnt bigint NOT NULL,
group_type character(1) NOT NULL,
frequency bigint NOT NULL,
class_b_ping_slot_period integer NOT NULL,
class_c_scheduling_type character varying(20) NOT NULL
pg_restore: error: could not execute query: ERROR: relation “multicast_group_device” already exists
Command was: CREATE TABLE public.multicast_group_device (
multicast_group_id uuid NOT NULL,
pg_restore: error: could not execute query: ERROR: relation “multicast_group_gateway” already exists
Command was: CREATE TABLE public.multicast_group_gateway (
pg_restore: error: could not execute query: ERROR: relation “multicast_group_queue_item” already exists
Command was: CREATE TABLE public.multicast_group_queue_item (
id uuid NOT NULL,
scheduler_run_after timestamp with time zone NOT NULL,
emit_at_time_since_gps_epoch bigint
pg_restore: error: could not execute query: ERROR: relation “relay_device” already exists
Command was: CREATE TABLE public.relay_device (
relay_dev_eui bytea NOT NULL,
pg_restore: error: could not execute query: ERROR: relation “tenant” already exists
Command was: CREATE TABLE public.tenant (
id uuid NOT NULL,
can_have_gateways boolean NOT NULL,
max_device_count integer NOT NULL,
max_gateway_count integer NOT NULL,
private_gateways_up boolean NOT NULL,
private_gateways_down boolean NOT NULL,
tags jsonb NOT NULL
pg_restore: error: could not execute query: ERROR: relation “tenant_user” already exists
Command was: CREATE TABLE public.tenant_user (
user_id uuid NOT NULL,
is_device_admin boolean NOT NULL,
is_gateway_admin boolean NOT NULL
pg_restore: error: could not execute query: ERROR: relation “user” already exists
Command was: CREATE TABLE public.“user” (
id uuid NOT NULL,
external_id text,
is_active boolean NOT NULL,
email text NOT NULL,
email_verified boolean NOT NULL,
password_hash character varying(200) NOT NULL,
note text NOT NULL
pg_restore: error: COPY failed for table “__diesel_schema_migrations”: ERROR: duplicate key value violates unique constraint “__diesel_schema_migrations_pkey”
DETAIL: Key (version)=(00000000000000) already exists.
CONTEXT: COPY __diesel_schema_migrations, line 1
pg_restore: error: COPY failed for table “tenant”: ERROR: duplicate key value violates unique constraint “tenant_pkey”
DETAIL: Key (id)=(52f14cd4-c6f1-4fbd-8f87-4025e1d49242) already exists.
CONTEXT: COPY tenant, line 1
pg_restore: error: COPY failed for table “user”: ERROR: duplicate key value violates unique constraint “user_pkey”
DETAIL: Key (id)=(05244f12-6daf-4e1f-8315-c66783a0ab56) already exists.
CONTEXT: COPY user, line 1
pg_restore: error: could not execute query: ERROR: multiple primary keys for table “__diesel_schema_migrations” are not allowed
Command was: ALTER TABLE ONLY public.__diesel_schema_migrations
ADD CONSTRAINT __diesel_schema_migrations_pkey PRIMARY KEY (version);
pg_restore: error: could not execute query: ERROR: multiple primary keys for table “api_key” are not allowed
Command was: ALTER TABLE ONLY public.api_key
ADD CONSTRAINT api_key_pkey PRIMARY KEY (id);
pg_restore: error: could not execute query: ERROR: multiple primary keys for table “application_integration” are not allowed
Command was: ALTER TABLE ONLY public.application_integration
ADD CONSTRAINT application_integration_pkey PRIMARY KEY (application_id, kind);
pg_restore: error: could not execute query: ERROR: multiple primary keys for table “application” are not allowed
ADD CONSTRAINT application_pkey PRIMARY KEY (id);
pg_restore: error: could not execute query: ERROR: multiple primary keys for table “device_keys” are not allowed
Command was: ALTER TABLE ONLY public.device_keys
ADD CONSTRAINT device_keys_pkey PRIMARY KEY (dev_eui);
pg_restore: error: could not execute query: ERROR: multiple primary keys for table “device” are not allowed
ADD CONSTRAINT device_pkey PRIMARY KEY (dev_eui);
pg_restore: error: could not execute query: ERROR: multiple primary keys for table “device_profile” are not allowed
Command was: ALTER TABLE ONLY public.device_profile
ADD CONSTRAINT device_profile_pkey PRIMARY KEY (id);
pg_restore: error: could not execute query: ERROR: multiple primary keys for table “device_profile_template” are not allowed
Command was: ALTER TABLE ONLY public.device_profile_template
ADD CONSTRAINT device_profile_template_pkey PRIMARY KEY (id);
pg_restore: error: could not execute query: ERROR: multiple primary keys for table “device_queue_item” are not allowed
Command was: ALTER TABLE ONLY public.device_queue_item
ADD CONSTRAINT device_queue_item_pkey PRIMARY KEY (id);
pg_restore: error: could not execute query: ERROR: multiple primary keys for table “gateway” are not allowed
Command was: ALTER TABLE ONLY public.gateway
ADD CONSTRAINT gateway_pkey PRIMARY KEY (gateway_id);
pg_restore: error: could not execute query: ERROR: multiple primary keys for table “multicast_group_device” are not allowed
Command was: ALTER TABLE ONLY public.multicast_group_device
ADD CONSTRAINT multicast_group_device_pkey PRIMARY KEY (multicast_group_id, dev_eui);
pg_restore: error: could not execute query: ERROR: multiple primary keys for table “multicast_group_gateway” are not allowed
Command was: ALTER TABLE ONLY public.multicast_group_gateway
ADD CONSTRAINT multicast_group_gateway_pkey PRIMARY KEY (multicast_group_id, gateway_id);
pg_restore: error: could not execute query: ERROR: multiple primary keys for table “multicast_group” are not allowed
ADD CONSTRAINT multicast_group_pkey PRIMARY KEY (id);
pg_restore: error: could not execute query: ERROR: multiple primary keys for table “multicast_group_queue_item” are not allowed
Command was: ALTER TABLE ONLY public.multicast_group_queue_item
ADD CONSTRAINT multicast_group_queue_item_pkey PRIMARY KEY (id);
pg_restore: error: could not execute query: ERROR: multiple primary keys for table “relay_device” are not allowed
Command was: ALTER TABLE ONLY public.relay_device
ADD CONSTRAINT relay_device_pkey PRIMARY KEY (relay_dev_eui, dev_eui);
pg_restore: error: could not execute query: ERROR: multiple primary keys for table “tenant” are not allowed
Command was: ALTER TABLE ONLY public.tenant
ADD CONSTRAINT tenant_pkey PRIMARY KEY (id);
pg_restore: error: could not execute query: ERROR: multiple primary keys for table “tenant_user” are not allowed
Command was: ALTER TABLE ONLY public.tenant_user
ADD CONSTRAINT tenant_user_pkey PRIMARY KEY (tenant_id, user_id);
pg_restore: error: could not execute query: ERROR: multiple primary keys for table “user” are not allowed
Command was: ALTER TABLE ONLY public.“user”
ADD CONSTRAINT user_pkey PRIMARY KEY (id);
pg_restore: error: could not execute query: ERROR: relation “idx_api_key_tenant_id” already exists
Command was: CREATE INDEX idx_api_key_tenant_id ON public.api_key USING btree (tenant_id);
pg_restore: error: could not execute query: ERROR: relation “idx_application_name_trgm” already exists
Command was: CREATE INDEX idx_application_name_trgm ON public.application USING gin (name public.gin_trgm_ops);
pg_restore: error: could not execute query: ERROR: relation “idx_application_tags” already exists
Command was: CREATE INDEX idx_application_tags ON public.application USING gin (tags);
pg_restore: error: could not execute query: ERROR: relation “idx_application_tenant_id” already exists
Command was: CREATE INDEX idx_application_tenant_id ON public.application USING btree (tenant_id);
pg_restore: error: could not execute query: ERROR: relation “idx_device_application_id” already exists
Command was: CREATE INDEX idx_device_application_id ON public.device USING btree (application_id);
pg_restore: error: could not execute query: ERROR: relation “idx_device_dev_addr_trgm” already exists
Command was: CREATE INDEX idx_device_dev_addr_trgm ON public.device USING gin (encode(dev_addr, ‘hex’::text) public.gin_trgm_ops);
pg_restore: error: could not execute query: ERROR: relation “idx_device_dev_eui_trgm” already exists
Command was: CREATE INDEX idx_device_dev_eui_trgm ON public.device USING gin (encode(dev_eui, ‘hex’::text) public.gin_trgm_ops);
pg_restore: error: could not execute query: ERROR: relation “idx_device_device_profile_id” already exists
Command was: CREATE INDEX idx_device_device_profile_id ON public.device USING btree (device_profile_id);
pg_restore: error: could not execute query: ERROR: relation “idx_device_name_trgm” already exists
Command was: CREATE INDEX idx_device_name_trgm ON public.device USING gin (name public.gin_trgm_ops);
pg_restore: error: could not execute query: ERROR: relation “idx_device_profile_name_trgm” already exists
Command was: CREATE INDEX idx_device_profile_name_trgm ON public.device_profile USING gin (name public.gin_trgm_ops);
pg_restore: error: could not execute query: ERROR: relation “idx_device_profile_tags” already exists
Command was: CREATE INDEX idx_device_profile_tags ON public.device_profile USING gin (tags);
pg_restore: error: could not execute query: ERROR: relation “idx_device_profile_tenant_id” already exists
Command was: CREATE INDEX idx_device_profile_tenant_id ON public.device_profile USING btree (tenant_id);
pg_restore: error: could not execute query: ERROR: relation “idx_device_queue_item_created_at” already exists
Command was: CREATE INDEX idx_device_queue_item_created_at ON public.device_queue_item USING btree (created_at);
pg_restore: error: could not execute query: ERROR: relation “idx_device_queue_item_dev_eui” already exists
Command was: CREATE INDEX idx_device_queue_item_dev_eui ON public.device_queue_item USING btree (dev_eui);
pg_restore: error: could not execute query: ERROR: relation “idx_device_queue_item_timeout_after” already exists
Command was: CREATE INDEX idx_device_queue_item_timeout_after ON public.device_queue_item USING btree (timeout_after);
pg_restore: error: could not execute query: ERROR: relation “idx_device_tags” already exists
Command was: CREATE INDEX idx_device_tags ON public.device USING gin (tags);
pg_restore: error: could not execute query: ERROR: relation “idx_gateway_id_trgm” already exists
Command was: CREATE INDEX idx_gateway_id_trgm ON public.gateway USING gin (encode(gateway_id, ‘hex’::text) public.gin_trgm_ops);
pg_restore: error: could not execute query: ERROR: relation “idx_gateway_name_trgm” already exists
Command was: CREATE INDEX idx_gateway_name_trgm ON public.gateway USING gin (name public.gin_trgm_ops);
pg_restore: error: could not execute query: ERROR: relation “idx_gateway_tags” already exists
Command was: CREATE INDEX idx_gateway_tags ON public.gateway USING gin (tags);
pg_restore: error: could not execute query: ERROR: relation “idx_gateway_tenant_id” already exists
Command was: CREATE INDEX idx_gateway_tenant_id ON public.gateway USING btree (tenant_id);
pg_restore: error: could not execute query: ERROR: relation “idx_multicast_group_application_id” already exists
Command was: CREATE INDEX idx_multicast_group_application_id ON public.multicast_group USING btree (application_id);
pg_restore: error: could not execute query: ERROR: relation “idx_multicast_group_name_trgm” already exists
Command was: CREATE INDEX idx_multicast_group_name_trgm ON public.multicast_group USING gin (name public.gin_trgm_ops);
pg_restore: error: could not execute query: ERROR: relation “idx_multicast_group_queue_item_multicast_group_id” already exists
Command was: CREATE INDEX idx_multicast_group_queue_item_multicast_group_id ON public.multicast_group_queue_item USING btree (multicast_group_id);
pg_restore: error: could not execute query: ERROR: relation “idx_multicast_group_queue_item_scheduler_run_after” already exists
Command was: CREATE INDEX idx_multicast_group_queue_item_scheduler_run_after ON public.multicast_group_queue_item USING btree (scheduler_run_after);
pg_restore: error: could not execute query: ERROR: relation “idx_tenant_name_trgm” already exists
Command was: CREATE INDEX idx_tenant_name_trgm ON public.tenant USING gin (name public.gin_trgm_ops);
pg_restore: error: could not execute query: ERROR: relation “idx_tenant_tags” already exists
Command was: CREATE INDEX idx_tenant_tags ON public.tenant USING gin (tags);
pg_restore: error: could not execute query: ERROR: relation “idx_tenant_user_user_id” already exists
Command was: CREATE INDEX idx_tenant_user_user_id ON public.tenant_user USING btree (user_id);
pg_restore: error: could not execute query: ERROR: relation “idx_user_email” already exists
Command was: CREATE UNIQUE INDEX idx_user_email ON public.“user” USING btree (email);
pg_restore: error: could not execute query: ERROR: relation “idx_user_external_id” already exists
Command was: CREATE UNIQUE INDEX idx_user_external_id ON public.“user” USING btree (external_id);
pg_restore: error: could not execute query: ERROR: constraint “api_key_tenant_id_fkey” for relation “api_key” already exists
ADD CONSTRAINT api_key_tenant_id_fkey FOREIGN KEY (tenant_id) REFERENCES public.tenant(id) ON DELETE CASCADE;
pg_restore: error: could not execute query: ERROR: constraint “application_integration_application_id_fkey” for relation “application_integration” already exists
ADD CONSTRAINT application_integration_application_id_fkey FOREIGN KEY (application_id) REFERENCES public.application(id) ON DELETE CASCADE;
pg_restore: error: could not execute query: ERROR: constraint “application_tenant_id_fkey” for relation “application” already exists
ADD CONSTRAINT application_tenant_id_fkey FOREIGN KEY (tenant_id) REFERENCES public.tenant(id) ON DELETE CASCADE;
pg_restore: error: could not execute query: ERROR: constraint “device_application_id_fkey” for relation “device” already exists
ADD CONSTRAINT device_application_id_fkey FOREIGN KEY (application_id) REFERENCES public.application(id) ON DELETE CASCADE;
pg_restore: error: could not execute query: ERROR: constraint “device_device_profile_id_fkey” for relation “device” already exists
ADD CONSTRAINT device_device_profile_id_fkey FOREIGN KEY (device_profile_id) REFERENCES public.device_profile(id) ON DELETE CASCADE;
pg_restore: error: could not execute query: ERROR: constraint “device_keys_dev_eui_fkey” for relation “device_keys” already exists
ADD CONSTRAINT device_keys_dev_eui_fkey FOREIGN KEY (dev_eui) REFERENCES public.device(dev_eui) ON DELETE CASCADE;
pg_restore: error: could not execute query: ERROR: constraint “device_profile_tenant_id_fkey” for relation “device_profile” already exists
ADD CONSTRAINT device_profile_tenant_id_fkey FOREIGN KEY (tenant_id) REFERENCES public.tenant(id) ON DELETE CASCADE;
pg_restore: error: could not execute query: ERROR: constraint “device_queue_item_dev_eui_fkey” for relation “device_queue_item” already exists
ADD CONSTRAINT device_queue_item_dev_eui_fkey FOREIGN KEY (dev_eui) REFERENCES public.device(dev_eui) ON DELETE CASCADE;
pg_restore: error: could not execute query: ERROR: constraint “gateway_tenant_id_fkey” for relation “gateway” already exists
ADD CONSTRAINT gateway_tenant_id_fkey FOREIGN KEY (tenant_id) REFERENCES public.tenant(id) ON DELETE CASCADE;
pg_restore: error: could not execute query: ERROR: constraint “multicast_group_application_id_fkey” for relation “multicast_group” already exists
ADD CONSTRAINT multicast_group_application_id_fkey FOREIGN KEY (application_id) REFERENCES public.application(id) ON DELETE CASCADE;
pg_restore: error: could not execute query: ERROR: constraint “multicast_group_device_dev_eui_fkey” for relation “multicast_group_device” already exists
ADD CONSTRAINT multicast_group_device_dev_eui_fkey FOREIGN KEY (dev_eui) REFERENCES public.device(dev_eui) ON DELETE CASCADE;
pg_restore: error: could not execute query: ERROR: constraint “multicast_group_device_multicast_group_id_fkey” for relation “multicast_group_device” already exists
ADD CONSTRAINT multicast_group_device_multicast_group_id_fkey FOREIGN KEY (multicast_group_id) REFERENCES public.multicast_group(id) ON DELETE CASCADE;
pg_restore: error: could not execute query: ERROR: constraint “multicast_group_gateway_gateway_id_fkey” for relation “multicast_group_gateway” already exists
ADD CONSTRAINT multicast_group_gateway_gateway_id_fkey FOREIGN KEY (gateway_id) REFERENCES public.gateway(gateway_id) ON DELETE CASCADE;
pg_restore: error: could not execute query: ERROR: constraint “multicast_group_gateway_multicast_group_id_fkey” for relation “multicast_group_gateway” already exists
ADD CONSTRAINT multicast_group_gateway_multicast_group_id_fkey FOREIGN KEY (multicast_group_id) REFERENCES public.multicast_group(id) ON DELETE CASCADE;
pg_restore: error: could not execute query: ERROR: constraint “multicast_group_queue_item_gateway_id_fkey” for relation “multicast_group_queue_item” already exists
ADD CONSTRAINT multicast_group_queue_item_gateway_id_fkey FOREIGN KEY (gateway_id) REFERENCES public.gateway(gateway_id) ON DELETE CASCADE;
pg_restore: error: could not execute query: ERROR: constraint “multicast_group_queue_item_multicast_group_id_fkey” for relation “multicast_group_queue_item” already exists
ADD CONSTRAINT multicast_group_queue_item_multicast_group_id_fkey FOREIGN KEY (multicast_group_id) REFERENCES public.multicast_group(id) ON DELETE CASCADE;
pg_restore: error: could not execute query: ERROR: constraint “relay_device_dev_eui_fkey” for relation “relay_device” already exists
ADD CONSTRAINT relay_device_dev_eui_fkey FOREIGN KEY (dev_eui) REFERENCES public.device(dev_eui) ON DELETE CASCADE;
pg_restore: error: could not execute query: ERROR: constraint “relay_device_relay_dev_eui_fkey” for relation “relay_device” already exists
ADD CONSTRAINT relay_device_relay_dev_eui_fkey FOREIGN KEY (relay_dev_eui) REFERENCES public.device(dev_eui) ON DELETE CASCADE;
pg_restore: error: could not execute query: ERROR: constraint “tenant_user_tenant_id_fkey” for relation “tenant_user” already exists
ADD CONSTRAINT tenant_user_tenant_id_fkey FOREIGN KEY (tenant_id) REFERENCES public.tenant(id) ON DELETE CASCADE;
pg_restore: error: could not execute query: ERROR: constraint “tenant_user_user_id_fkey” for relation “tenant_user” already exists
ADD CONSTRAINT tenant_user_user_id_fkey FOREIGN KEY (user_id) REFERENCES public.“user”(id) ON DELETE CASCADE;
pg_restore: warning: errors ignored on restore: 88
ln: /var/lib/redis/redis: File exists
