I install chirpstack V4 on ubuntu 22.04. After some test with the LPS8-V2 gateway from dragino, everything work fine. But now the gateway wont connect to the server for the past 24 hours after upgrade some dependencies (postsql, Chirpstack-Gate-Bridge, etc).
First, I thought it was due to my host’s firewall blocking UTP 1700.
But i don’t think so :
- I can ping UTP 1700 with an another server.
- With tcpdump on UTP 1700 i’ve my gateway json stat every 30s
So, I tried to re-install chirpstack, but the gateway still wont connect.
With journactl, i’ve “Backend interfaces API is disabled”. I saw on the forum it can come from MQTT config. So now i don’t understand because i use the same config as my first install.
Can you help me ?
Thanks in avance,
