Main process exited, code=exited, status=1/FAILURE
I have install gateway bridge + loraserver + lora app server on a RPI3.
No problem with the GW bridge nor loraserver, but LoRa App Server return me some error in the log :
    Jun 11 11:57:36 raspberrypi systemd[1]: Started LoRa App Server.
Jun 11 11:57:36 raspberrypi systemd[1]: lora-app-server.service: Main process exited, code=exited, status=1/FAILURE
Jun 11 11:57:36 raspberrypi systemd[1]: lora-app-server.service: Unit entered failed state.
Jun 11 11:57:36 raspberrypi systemd[1]: lora-app-server.service: Failed with result 'exit-code'.
Jun 11 11:57:36 raspberrypi systemd[1]: lora-app-server.service: Service hold-off time over, scheduling restart.
Jun 11 11:57:36 raspberrypi systemd[1]: Stopped LoRa App Server.
Jun 11 11:57:37 raspberrypi systemd[1]: lora-app-server.service: Service hold-off time over, scheduling restart.
Jun 11 11:57:37 raspberrypi systemd[1]: Stopped LoRa App Server.
Jun 11 11:57:37 raspberrypi systemd[1]: Started LoRa App Server.
Jun 11 11:57:37 raspberrypi systemd[1]: lora-app-server.service: Main process exited, code=exited, status=1/FAILURE
Jun 11 11:57:37 raspberrypi systemd[1]: lora-app-server.service: Unit entered failed state.
Jun 11 11:57:37 raspberrypi systemd[1]: lora-app-server.service: Failed with result 'exit-code'.
Jun 11 11:57:37 raspberrypi systemd[1]: lora-app-server.service: Start request repeated too quickly.
Jun 11 11:57:37 raspberrypi systemd[1]: Failed to start LoRa App Server.
I don’t understand this line of the tutorial :
https://www.loraserver.io/lora-app-server/install/debian/
“An other required setting you must change is application_server.external_api.jwt_secret.” What I must do ?
My Lora App Server dsn is :
dsn="postgres://loraserver_as:dbpassword@localhost/loraserver_as?sslmode=disable"
I also add JWT :
jwt_secret=uxbpWQtBlxrWfHX+0wSmEt+/bqAFpPqU5hgmowYEO7o=
Thanks for your help !
Try running lora-app-server from the command-line interface. It might give you more hints about why it is not starting :slight_smile:
lora-app-server --config /etc/lora-app-server/lora-app-server.toml
It say :
root@raspberrypi:~/lora_gateway# lora-app-server --config /etc/lora-app-server/lora-app-server.toml
FATA[0000] error loading config file config=/etc/lora-app-server/lora-app-server.toml error=“While parsing config: (177, 3): The following key was defined twice: application_server.external_api.jwt_secret.bind”
I think the problem is link to my first question :
I not sure what I must do about the application_server.external…
You must configure that value, see:
  # Settings for the "external api"
  # This is the API and web-interface exposed to the end-user.
  # JWT secret used for api authentication / authorization
  # You could generate this by executing 'openssl rand -base64 32' for example
  jwt_secret=""
Oups, It’s my fault, first I had not complete the jwt_secret. After some search I had complete it, but don’t know why, I also commented the line “[application_server.api]” and it was the problem !!
Now all is OK, my device can send data trought LoraWan.
Just some questions : where I must use the appeui ? I don’t see where I can use them. I know that on commercial GW I must provide DevEUI, AppKey and AppEUI but in this case I only used DevEUI and AppKey.
Let’s not mix different questions in one topic :slight_smile: There is already an other topic covering this question when you search on AppEUI.
After a reboot lora-app-server don’t start automatly (same error as before), but If I launch them with the command : lora-app-server --config /etc/lora-app-server/lora-app-server.toml all is ok
Error :
>     Jun 14 14:50:14 raspberrypi systemd[1]: Started LoRa App Server.
>     Jun 14 14:50:14 raspberrypi lora-app-server[1591]: time="2018-06-14T14:50:14Z" level=info msg="starting LoRa App Server" docs="https://www.loraserver.io/" version=1.0.1
>     Jun 14 14:50:14 raspberrypi lora-app-server[1591]: time="2018-06-14T14:50:14Z" level=info msg="connecting to postgresql"
>     Jun 14 14:50:14 raspberrypi lora-app-server[1591]: time="2018-06-14T14:50:14Z" level=info msg="setup redis connection pool"
>     Jun 14 14:50:14 raspberrypi systemd[1]: lora-app-server.service: Main process exited, code=exited, status=1/FAILURE
>     Jun 14 14:50:15 raspberrypi systemd[1]: lora-app-server.service: Unit entered failed state.
>     Jun 14 14:50:15 raspberrypi systemd[1]: lora-app-server.service: Failed with result 'exit-code'.
>     Jun 14 14:50:15 raspberrypi systemd[1]: lora-app-server.service: Service hold-off time over, scheduling restart.
>     Jun 14 14:50:15 raspberrypi systemd[1]: Stopped LoRa App Server.
>     Jun 14 14:50:15 raspberrypi systemd[1]: Started LoRa App Server.
>     Jun 14 14:50:15 raspberrypi lora-app-server[1598]: time="2018-06-14T14:50:15Z" level=info msg="starting LoRa App Server" docs="https://www.loraserver.io/" version=1.0.1
>     Jun 14 14:50:15 raspberrypi lora-app-server[1598]: time="2018-06-14T14:50:15Z" level=info msg="connecting to postgresql"
>     Jun 14 14:50:15 raspberrypi lora-app-server[1598]: time="2018-06-14T14:50:15Z" level=info msg="setup redis connection pool"
>     Jun 14 14:50:15 raspberrypi systemd[1]: lora-app-server.service: Main process exited, code=exited, status=1/FAILURE
>     Jun 14 14:50:15 raspberrypi lora-app-server[1606]: time="2018-06-14T14:50:15Z" level=info msg="starting LoRa App Server" docs="https://www.loraserver.io/" version=1.0.1
>     Jun 14 14:50:15 raspberrypi lora-app-server[1606]: time="2018-06-14T14:50:15Z" level=info msg="connecting to postgresql"
>     Jun 14 14:50:15 raspberrypi lora-app-server[1606]: time="2018-06-14T14:50:15Z" level=info msg="setup redis connection pool"
>     Jun 14 14:50:15 raspberrypi lora-app-server[1613]: time="2018-06-14T14:50:15Z" level=info msg="starting LoRa App Server" docs="https://www.loraserver.io/" version=1.0.1
>     Jun 14 14:50:15 raspberrypi lora-app-server[1613]: time="2018-06-14T14:50:15Z" level=info msg="connecting to postgresql"
>     Jun 14 14:50:15 raspberrypi lora-app-server[1613]: time="2018-06-14T14:50:15Z" level=info msg="setup redis connection pool"
>     Jun 14 14:50:16 raspberrypi systemd[1]: lora-app-server.service: Service hold-off time over, scheduling restart.
>     Jun 14 14:50:16 raspberrypi systemd[1]: Stopped LoRa App Server.
>     Jun 14 14:50:16 raspberrypi systemd[1]: Started LoRa App Server.
>     Jun 14 14:50:16 raspberrypi lora-app-server[1620]: time="2018-06-14T14:50:16Z" level=info msg="starting LoRa App Server" docs="https://www.loraserver.io/" version=1.0.1
>     Jun 14 14:50:16 raspberrypi lora-app-server[1620]: time="2018-06-14T14:50:16Z" level=info msg="connecting to postgresql"
>     Jun 14 14:50:16 raspberrypi lora-app-server[1620]: time="2018-06-14T14:50:16Z" level=info msg="setup redis connection pool"
>     Jun 14 14:50:16 raspberrypi systemd[1]: lora-app-server.service: Main process exited, code=exited, status=1/FAILURE
>     Jun 14 14:50:16 raspberrypi systemd[1]: lora-app-server.service: Unit entered failed state.
>     Jun 14 14:50:16 raspberrypi systemd[1]: lora-app-server.service: Failed with result 'exit-code'.
>     Jun 14 14:50:16 raspberrypi systemd[1]: lora-app-server.service: Start request repeated too quickly.
>     Jun 14 14:50:16 raspberrypi systemd[1]: Failed to start LoRa App Server.
>     Jun 14 14:50:32 raspberrypi systemd[1]: Started LoRa App Server.
>     Jun 14 14:50:32 raspberrypi lora-app-server[1634]: time="2018-06-14T14:50:32Z" level=info msg="starting LoRa App Server" docs="https://www.loraserver.io/" version=1.0.1
>     Jun 14 14:50:32 raspberrypi lora-app-server[1634]: time="2018-06-14T14:50:32Z" level=info msg="connecting to postgresql"
>     Jun 14 14:50:32 raspberrypi lora-app-server[1634]: time="2018-06-14T14:50:32Z" level=info msg="setup redis connection pool"
>     Jun 14 14:50:32 raspberrypi systemd[1]: lora-app-server.service: Main process exited, code=exited, status=1/FAILURE
>     Jun 14 14:50:32 raspberrypi systemd[1]: lora-app-server.service: Unit entered failed state.
>     Jun 14 14:50:32 raspberrypi systemd[1]: lora-app-server.service: Failed with result 'exit-code'.
>     Jun 14 14:50:32 raspberrypi systemd[1]: lora-app-server.service: Service hold-off time over, scheduling restart.
>     Jun 14 14:50:32 raspberrypi systemd[1]: Stopped LoRa App Server.
>     Jun 14 14:50:32 raspberrypi lora-app-server[1643]: time="2018-06-14T14:50:32Z" level=info msg="starting LoRa App Server" docs="https://www.loraserver.io/" version=1.0.1
>     Jun 14 14:50:32 raspberrypi lora-app-server[1643]: time="2018-06-14T14:50:32Z" level=info msg="connecting to postgresql"
>     Jun 14 14:50:32 raspberrypi lora-app-server[1643]: time="2018-06-14T14:50:32Z" level=info msg="setup redis connection pool"
>     Jun 14 14:50:32 raspberrypi lora-app-server[1650]: time="2018-06-14T14:50:32Z" level=info msg="starting LoRa App Server" docs="https://www.loraserver.io/" version=1.0.1
>     Jun 14 14:50:32 raspberrypi lora-app-server[1650]: time="2018-06-14T14:50:32Z" level=info msg="connecting to postgresql"
>     Jun 14 14:50:32 raspberrypi lora-app-server[1650]: time="2018-06-14T14:50:32Z" level=info msg="setup redis connection pool"
>     Jun 14 14:50:33 raspberrypi systemd[1]: lora-app-server.service: Service hold-off time over, scheduling restart.
>     Jun 14 14:50:33 raspberrypi systemd[1]: Stopped LoRa App Server.
>     Jun 14 14:50:33 raspberrypi systemd[1]: Started LoRa App Server.
>     Jun 14 14:50:33 raspberrypi lora-app-server[1659]: time="2018-06-14T14:50:33Z" level=info msg="starting LoRa App Server" docs="https://www.loraserver.io/" version=1.0.1
>     Jun 14 14:50:33 raspberrypi lora-app-server[1659]: time="2018-06-14T14:50:33Z" level=info msg="connecting to postgresql"
>     Jun 14 14:50:33 raspberrypi systemd[1]: lora-app-server.service: Main process exited, code=exited, status=1/FAILURE
>     Jun 14 14:50:33 raspberrypi systemd[1]: lora-app-server.service: Unit entered failed state.
>     Jun 14 14:50:33 raspberrypi systemd[1]: lora-app-server.service: Failed with result 'exit-code'.
>     Jun 14 14:50:33 raspberrypi lora-app-server[1667]: time="2018-06-14T14:50:33Z" level=info msg="starting LoRa App Server" docs="https://www.loraserver.io/" version=1.0.1
>     Jun 14 14:50:33 raspberrypi lora-app-server[1667]: time="2018-06-14T14:50:33Z" level=info msg="connecting to postgresql"
>     Jun 14 14:50:33 raspberrypi lora-app-server[1667]: time="2018-06-14T14:50:33Z" level=info msg="setup redis connection pool"
>     Jun 14 14:50:33 raspberrypi lora-app-server[1667]: time="2018-06-14T14:50:33Z" level=error msg="handler/mqtt: couldn't load MQTT TLS key pair: open /root/cert.pem: permission denied"
>     Jun 14 14:50:33 raspberrypi lora-app-server[1667]: time="2018-06-14T14:50:33Z" level=fatal msg="error loading mqtt certificate files" ca_cert= error="open /root/cert.pem: permission denied" tls_cert=/root/cert.pem tls_key=/root/key.pem
>     Jun 14 14:50:33 raspberrypi systemd[1]: lora-app-server.service: Start request repeated too quickly.
>     Jun 14 14:50:33 raspberrypi systemd[1]: Failed to start LoRa App Server.
Do you know why ??
Thanks :slight_smile:
I believe here’s the answer:
I must change my glasses !!! Don’t see this lines.
Where is the right place to put them ? I see the files are property of root, which user and/or group I must put for this files ?
The answer :
mv cert.pem key.pem /etc/lora-app-server/certs
cd /etc/lora-app-server/certs
chmod 640 cert.pem
chmod 640 key.pem
chown appserver:appserver cert.pem
chown appserver:appserver key.pem
Yeah, that should do. If you go to production and choose to use Let’s Encrypt certificates, just be careful as by default the certbot will position them at /etc/letsencrypt/live/your-domain/ as root on renewal, so you’ll maybe have to add some hook to move certs or rewrite permissions after it.
Hi Guys, I think a have a similar issue, but I’m really struggling here.
I have completed the instructions and the gateway bridge and the loraserver are fine, however, my issue is with the lora-app-server:
When I execute: journalctl -u lora-app-server -f -n 50
– Logs begin at Thu 2018-06-28 14:19:46 BST. –
Jul 03 13:24:50 debian systemd[1]: Started LoRa App Server.
Jul 03 13:24:50 debian systemd[1]: lora-app-server.service: Main process exited, code=exited, status=1/FAILURE
Jul 03 13:24:50 debian systemd[1]: lora-app-server.service: Unit entered failed state.
Jul 03 13:24:50 debian systemd[1]: lora-app-server.service: Failed with result ‘exit-code’.
Jul 03 13:24:50 debian systemd[1]: lora-app-server.service: Service hold-off time over, scheduling restart.
Jul 03 13:24:50 debian systemd[1]: Stopped LoRa App Server.
Jul 03 13:24:50 debian systemd[1]: lora-app-server.service: Start request repeated too quickly.
Jul 03 13:24:50 debian systemd[1]: Failed to start LoRa App Server.
Jul 03 13:42:19 debian systemd[1]: Started LoRa App Server.
Jul 03 13:42:19 debian systemd[1]: lora-app-server.service: Main process exited, code=exited, status=1/FAILURE
Jul 03 13:42:19 debian systemd[1]: lora-app-server.service: Unit entered failed state.
Jul 03 13:42:19 debian systemd[1]: lora-app-server.service: Failed with result ‘exit-code’.
Jul 03 13:42:19 debian systemd[1]: lora-app-server.service: Service hold-off time over, scheduling restart.
Jul 03 13:42:19 debian systemd[1]: Stopped LoRa App Server.
Jul 03 13:42:20 debian systemd[1]: lora-app-server.service: Service hold-off time over, scheduling restart.
Jul 03 13:42:20 debian systemd[1]: Stopped LoRa App Server.
Jul 03 13:42:20 debian systemd[1]: Started LoRa App Server.
Jul 03 13:42:20 debian systemd[1]: lora-app-server.service: Main process exited, code=exited, status=1/FAILURE
Jul 03 13:42:20 debian systemd[1]: lora-app-server.service: Unit entered failed state.
Jul 03 13:42:20 debian systemd[1]: lora-app-server.service: Failed with result ‘exit-code’.
Jul 03 13:42:20 debian systemd[1]: lora-app-server.service: Start request repeated too quickly.
Jul 03 13:42:20 debian systemd[1]: Failed to start LoRa App Server.
and when i execute: lora-app-server --config /etc/lora-app-server/lora-app-server.toml
FATA[0000] error loading config file config=/etc/lora-app-server/lora-app-server.toml error=“While parsing config: (186, 3): The following key was defined twice: application_server.external_api.jwt_secret”
i already used “openssl rand -base64 32” and updated the “jwt_secret=”
any ideas please??
Many thanks
I thinks that explains it all :slight_smile:
Thanks for your fast response (as usual :slight_smile:)
I have already used the “openssl rand -base64 32” and updated the “jwt_secret=”
is there anything that i need to do in order for this to take effect except saving the lora-app-server.toml file?
Cheers
The error says you have defined it twice in your config file, it should only be there once. So you have to remove the duplicate.
@brocaar @iegomez
Why is my https crossed over when inserting the key and cert on lora-app-server from the commando
openssl req -x509 -newkey rsa:2048 -keyout key.pem -out cert.pem -days 90 -nodes
03
The certificate is not accepted
If you are using a self-signed certificate you need to tell your browser to trust it. How to do that should be browser specific.
Hi, im facing same issue.
Failed to start Lora Server
Process: 851 ExecStart=/usr/bin/loraserver (code=exited, status=1/Failure)
FATA[0000] error loading config file config=/etc/loraserver.toml error “open /etc/loraserver.toml: no such file or directory”
Why no one of you not read the error messages, when they clearly include the reason and the solution of the problem is obvious?
file is already in the directory. I can even edit it
