I’ve this two boards : TTGO ESP32 SX1276
I test the P2P communication with this two boards and it works well but I read that the max range is about 1km
I want to pass at the next level and create a LoraWan gateway.
I’ve install on a Raspberry with docker the Chirpstack stack (Gateway Bridge, Network Server, App Server, Redis and Postgres) and I can access to the app server Interface and add the Network server.
The final question is :
Can I make a LoraWan Gateway with one of the TTGO ESP32 SX1276 module (because I’ve just this one for now) for testing the communication with the chirpstack Gateway bridge ?
I’ve some difficulties to find a article about this. I can see some articles with 1 channel gateway…
The different 8 channel concentrator board are expensive and I want to validate I can make my own gateway before buying.
If it’s not possible have you a advice for buy a non expensive gateway ?
My differents final use case are with
p2p : mailbox communication (>40m)
Gateway : Test communication between two house (about 15km)
Thanks
