Recently this error appears to me, i’ve reinstall everything, read the posts here and nothing work.
When i try to register a new gateway, this happen.
And also here.
I can’t really find the error, everything looks set up right.
Output from journalctl -u chirpstack-application-server -f -n 50
mar 18 21:07:19 victorUTF chirpstack-application-server[1124]: time="2020-03-18T21:07:19-03:00" level=info msg="finished unary call with code OK" ctx_id=f949b931-cb4b-428f-986f-b379fc295799 grpc.code=OK grpc.method=List grpc.service=api.NetworkServerService grpc.start_time="2020-03-18T21:07:19-03:00" grpc.time_ms=4.048 peer.address="127.0.0.1:42300" span.kind=server system=grpc
mar 18 21:07:19 victorUTF chirpstack-application-server[1124]: time="2020-03-18T21:07:19-03:00" level=warning msg="creating insecure network-server client" server="localhost:8000"
mar 18 21:07:24 victorUTF chirpstack-application-server[1124]: time="2020-03-18T21:07:24-03:00" level=info msg="finished unary call with code OK" ctx_id=254ff03e-aab9-4f72-a62f-0ef6d08ba861 grpc.code=OK grpc.method=Get grpc.service=api.NetworkServerService grpc.start_time="2020-03-18T21:07:19-03:00" grpc.time_ms=5003.745 peer.address="127.0.0.1:42300" span.kind=server system=grpc
mar 18 21:07:38 victorUTF chirpstack-application-server[1124]: time="2020-03-18T21:07:38-03:00" level=info msg="gateway created" ctx_id=bf05996f-243d-427e-9008-6307f1e57401 id=b827ebffff839157 name=RHF0M301
mar 18 21:07:38 victorUTF chirpstack-application-server[1124]: time="2020-03-18T21:07:38-03:00" level=warning msg="creating insecure network-server client" server="localhost:8000"
mar 18 21:07:43 victorUTF chirpstack-application-server[1124]: time="2020-03-18T21:07:43-03:00" level=error msg="finished unary call with code Unknown" ctx_id=bf05996f-243d-427e-9008-6307f1e57401 error="rpc error: code = Unknown desc = context deadline exceeded" grpc.code=Unknown grpc.method=Create grpc.service=api.GatewayService grpc.start_time="2020-03-18T21:07:38-03:00" grpc.time_ms=5012.103 peer.address="127.0.0.1:42318" span.kind=server system=grpc
mar 18 21:07:43 victorUTF chirpstack-application-server[1124]: time="2020-03-18T21:07:43-03:00" level=info msg="gateway created" ctx_id=254674ce-913b-42a3-8769-837527f950bc id=b827ebffff839157 name=RHF0M301
mar 18 21:07:43 victorUTF chirpstack-application-server[1124]: time="2020-03-18T21:07:43-03:00" level=warning msg="creating insecure network-server client" server="localhost:8000"
mar 18 21:07:48 victorUTF chirpstack-application-server[1124]: time="2020-03-18T21:07:48-03:00" level=error msg="finished unary call with code Unknown" ctx_id=254674ce-913b-42a3-8769-837527f950bc error="rpc error: code = Unknown desc = context deadline exceeded" grpc.code=Unknown grpc.method=Create grpc.service=api.GatewayService grpc.start_time="2020-03-18T21:07:41-03:00" grpc.time_ms=7768.594 peer.address="127.0.0.1:42318" span.kind=server system=grpc
My chirpstack-application-server.toml
# This configuration sets the required settings and configures an integration
# with a MQTT broker. Many options and defaults have been omitted for
# simplicity.
# See https://www.chirpstack.io/application-server/install/config/ for a full
# configuration example and documentation.
# PostgreSQL settings.
# Please note that PostgreSQL 9.5+ is required.
[postgresql]
# PostgreSQL dsn (e.g.: postgres://user:password@hostname/database?sslmode=disable).
# Besides using an URL (e.g. 'postgres://user:password@hostname/database?sslmode=disable')
# it is also possible to use the following format:
# 'user=chirpstack_as dbname=chirpstack_as sslmode=disable'.
# The following connection parameters are supported:
# * dbname - The name of the database to connect to
# * user - The user to sign in as
# * password - The user's password
# * host - The host to connect to. Values that start with / are for unix domain sockets. (default is localhost)
# * port - The port to bind to. (default is 5432)
# * sslmode - Whether or not to use SSL (default is require, this is not the default for libpq)
# * fallback_application_name - An application_name to fall back to if one isn't provided.
# * connect_timeout - Maximum wait for connection, in seconds. Zero or not specified means wait indefinitely.
# * sslcert - Cert file location. The file must contain PEM encoded data.
# * sslkey - Key file location. The file must contain PEM encoded data.
# * sslrootcert - The location of the root certificate file. The file must contain PEM encoded data.
# Valid values for sslmode are:
# * disable - No SSL
dsn="postgres://victor_as:tcc@localhost/chirpstack_as?sslmode=disable"
# Redis settings
# Please note that Redis 2.6.0+ is required.
[redis]
# Redis url (e.g. redis://user:password@hostname/0)
# For more information about the Redis URL format, see:
# https://www.iana.org/assignments/uri-schemes/prov/redis
url="redis://localhost:6379"
# Application-server settings.
[application_server]
# Integration configures the data integration.
# This is the data integration which is available for all applications,
# besides the extra integrations that can be added on a per-application
# basis.
# Enabled integrations.
enabled=["mqtt"]
# MQTT integration backend.
# MQTT topic templates for the different MQTT topics.
# The meaning of these topics are documented at:
# https://www.chirpstack.io/application-server/integrate/data/
# The following substitutions can be used:
# * "{{ .ApplicationID }}" for the application id.
# * "{{ .DevEUI }}" for the DevEUI of the device.
# Note: the downlink_topic_template must contain both the application id and
# DevEUI substitution!
uplink_topic_template="application/{{ .ApplicationID }}/device/{{ .DevEUI }}/rx"
downlink_topic_template="application/{{ .ApplicationID }}/device/{{ .DevEUI }}/tx"
join_topic_template="application/{{ .ApplicationID }}/device/{{ .DevEUI }}/join"
ack_topic_template="application/{{ .ApplicationID }}/device/{{ .DevEUI }}/ack"
error_topic_template="application/{{ .ApplicationID }}/device/{{ .DevEUI }}/error"
status_topic_template="application/{{ .ApplicationID }}/device/{{ .DevEUI }}/status"
location_topic_template="application/{{ .ApplicationID }}/device/{{ .DevEUI }}/location"
server="tcp://localhost:1883"
username=""
password=""
# Settings for the "internal api"
# This is the API used by ChirpStack Network Server to communicate with ChirpStack Application Server
# and should not be exposed to the end-user.
[application_server.api]
bind="0.0.0.0:8001"
# Public ip:port of the application-server API.
# This is used by ChirpStack Network Server to connect to ChirpStack Application Server. When running
# ChirpStack Application Server on a different host than ChirpStack Network Server, make sure to set
# this to the host:ip on which ChirpStack Network Server can reach ChirpStack Application Server.
# The port must be equal to the port configured by the 'bind' flag
# above.
public_host="localhost:8001"
# Settings for the "external api"
# This is the API and web-interface exposed to the end-user.
# ip:port to bind the (user facing) http server to (web-interface and REST / gRPC api)
bind="0.0.0.0:8080"
# http server TLS certificate (optional)
tls_cert=""
# http server TLS key (optional)
tls_key=""
# JWT secret used for api authentication / authorization
# You could generate this by executing 'openssl rand -base64 32' for example
jwt_secret="G8vPeaQ9qYjKacVgXeIUgr+6ZtQUzBZ5u+XMmXtFfYM="
# Join-server configuration.
# ChirpStack Application Server implements a (subset) of the join-api specified by the
# LoRaWAN Backend Interfaces specification. This API is used by ChirpStack Network Server
# to handle join-requests.
[join_server]
# ip:port to bind the join-server api interface to
bind="0.0.0.0:8003"
Output from journalctl -u chirpstack-network-server -f -n 50
-- Reboot --
mar 18 20:47:44 victorUTF systemd[1]: Started ChirpStack Network Server.
mar 18 20:47:45 victorUTF chirpstack-network-server[1128]: time="2020-03-18T20:47:45-03:00" level=info msg="starting ChirpStack Network Server" band=US_902_928 docs="https://www.chirpstack.io/" net_id=000000 version=3.8.0
mar 18 20:47:45 victorUTF chirpstack-network-server[1128]: time="2020-03-18T20:47:45-03:00" level=info msg="disabling all channels"
mar 18 20:47:45 victorUTF chirpstack-network-server[1128]: time="2020-03-18T20:47:45-03:00" level=info msg="enabling channels" channels="[0 1 2 3 4 5 6 7]"
mar 18 20:47:45 victorUTF chirpstack-network-server[1128]: time="2020-03-18T20:47:45-03:00" level=info msg="storage: setting up storage module"
mar 18 20:47:45 victorUTF chirpstack-network-server[1128]: time="2020-03-18T20:47:45-03:00" level=info msg="storage: setting up Redis connection pool"
mar 18 20:47:45 victorUTF chirpstack-network-server[1128]: time="2020-03-18T20:47:45-03:00" level=info msg="storage: connecting to PostgreSQL"
mar 18 20:47:45 victorUTF chirpstack-network-server[1128]: time="2020-03-18T20:47:45-03:00" level=info msg="storage: applying PostgreSQL data migrations"
mar 18 20:47:46 victorUTF chirpstack-network-server[1128]: time="2020-03-18T20:47:46-03:00" level=info msg="storage: PostgreSQL data migrations applied" count=0
mar 18 20:47:46 victorUTF chirpstack-network-server[1128]: time="2020-03-18T20:47:46-03:00" level=info msg="gateway/mqtt: connecting to mqtt broker" server="tcp://localhost:1883"
mar 18 20:47:46 victorUTF chirpstack-network-server[1128]: time="2020-03-18T20:47:46-03:00" level=info msg="no geolocation-server configured"
mar 18 20:47:46 victorUTF chirpstack-network-server[1128]: time="2020-03-18T20:47:46-03:00" level=info msg="configuring join-server client" ca_cert= server="http://localhost:8003" tls_cert= tls_key=
mar 18 20:47:46 victorUTF chirpstack-network-server[1128]: time="2020-03-18T20:47:46-03:00" level=info msg="backend/gateway: connected to mqtt server"
mar 18 20:47:46 victorUTF chirpstack-network-server[1128]: time="2020-03-18T20:47:46-03:00" level=info msg="gateway/mqtt: subscribing to gateway event topic" qos=0 topic=gateway/+/event/+
mar 18 20:47:46 victorUTF chirpstack-network-server[1128]: time="2020-03-18T20:47:46-03:00" level=info msg="api: starting network-server api server" bind="0.0.0.0:8000" ca-cert= tls-cert= tls-key=
mar 18 20:47:46 victorUTF chirpstack-network-server[1128]: time="2020-03-18T20:47:46-03:00" level=info msg="starting downlink device-queue scheduler"
mar 18 20:47:46 victorUTF chirpstack-network-server[1128]: time="2020-03-18T20:47:46-03:00" level=info msg="starting multicast scheduler"
I appreciate any sugestion, thanks for now
