Mesh: Concentratord command loop has been interrupted
Hi, Guys,
We’re trying to set up Mesh in a RAK7289v2, US915. The concentratord works well without Mesh, but when We enable mesh and save, we have the follow error:
Thu May 15 18:31:22 2025 user.info chirpstack-gateway-mesh[9536]: Starting ChirpStack Gateway Mesh (border_gateway: true,version: 4.0.1, docs: https://www.chirpstack.io/)
Thu May 15 18:31:22 2025 user.info chirpstack-gateway-mesh[9536]: Setting up Concentratord proxy API, event_bind: ipc:///tmp/gateway_relay_event, command_bind: ipc:///tmp/gateway_relay_command
Thu May 15 18:31:22 2025 user.info chirpstack-gateway-mesh[9536]: Setting up Concentratord backend, event_url: ipc:///tmp/concentratord_event, command_url: ipc:///tmp/concentratord_command
Thu May 15 18:31:22 2025 user.err chirpstack-gateway-mesh[9536]: Concentratord command loop has been interrupted
Someone can help us?
Regards,
Sergio
