Method to send downlink MAC Commands to End Node
Hi All,
With the go script shown below, I am currently trying to figure out how to send downlink messages with MAC Commands to my end node: STM32L0 (b-l072z-lrwan1). At the LoRa App Server our device profile is LoRaWan Mac version 1.0.3 regional parameter 3, OTAA enabled, Class C device and the frame counter validation is disabled.
Firstly, I have been communicating to the LoRa server api through gRPC as mentioned in the code below. Here are a few issues currently that I would like help with:
  1. When I send downlink messages from the LoRa Server a downlink message is successfully sent out, but it fails to send the downlink with our MAC Command payload shown below in the script. Why is this occuring?
  2. I am unable to send downlink messages arbitrarily whenever I want. Is there a method to enable me to send whenever I’d like? grin:
Please find our code shown below for our go script with what the mac payload contains along with our Loraserver.toml script:
Go script:
package main
import(
“context”
“log”
“loraserver/api/ns”
“grpc package - google.golang.org/grpc - Go Packages”
“fmt”
“lorawan”
func main() {
grpcOpts := grpc.DialOption{
grpc.WithInsecure(),
asConn, err := grpc.Dial("0.0.0.0:8004", grpcOpts...)
if err != nil {
	log.Fatal(err)
fmt.Printf("%v\n",err)
NetworkServiceclient := ns.NewNetworkServerServiceClient(asConn)
ctx  := context.Background()
devEUI:= [8]byte{0,0,0,0,0,0,0,1}
mac := lorawan.MACCommand{
	CID: lorawan.LinkADRReq,
	Payload: &lorawan.LinkADRReqPayload{
		DataRate: uint8(0),
		TXPower: uint8(1),
		ChMask:[16]bool{true,true,true,true,true,true,true,true,true,true,true,true,false,true,true},
		Redundancy: lorawan.Redundancy{
			ChMaskCntl: uint8(0),
			NbRep: uint8(2),
b,err := mac.MarshalBinary()
resp,err :=  NetworkServiceclient.CreateMACCommandQueueItem(ctx,&ns.CreateMACCommandQueueItemRequest{
	DevEui: devEUI[:],
	Cid: uint32(lorawan.LinkADRReq), // command id is in hexidecimal 0x00
	Commands: [][]byte{b},
fmt.Printf("%s",resp)
    _, err = NetworkServiceclient.CreateDeviceQueueItem(ctx,&ns.CreateDeviceQueueItemRequest{
            Item: &ns.DeviceQueueItem{
                    DevEui: devEUI[:],
                    FrmPayload: []byte{1,2,3,4},
                    FCnt: 3005,
                    FPort: 1,
                    Confirmed: false,
[general]
log_level=4
[postgresql]
dsn=“postgres://loraserver_ns:dbpassword@localhost/loraserver_ns?sslmode=disable”
automigrate=true
[redis]
url=“redis://localhost:6379”
max_idle=10
idle_timeout=“5m0s”
[network_server]
net_id=“000000”
deduplication_delay=“200ms”
device_session_ttl=“744h0m0s”
get_downlink_data_delay=“100ms”
[network_server.band]
name=“US_902_928”
dwell_time_400ms=false
repeater_compatible=false
installation_margin=10
rx_window=0
rx1_delay=1
rx1_dr_offset=0
rx2_dr=-1
rx2_frequency=-1
downlink_tx_power=-1
disable_mac_commands=false
disable_adr=false
enabled_uplink_channels=
[network_server.network_settings.class_b]
ping_slot_dr=0
ping_slot_frequency=0
[network_server.network_settings.rejoin_request]
enabled=true
max_count_n=0
max_time_n=0
[network_server.scheduler]
scheduler_interval=“1s”
[network_server.scheduler.class_c]
downlink_lock_duration="2s"
[network_server.api]
bind=“0.0.0.0:8004”
ca_cert=“”
tls_cert=“”
tls_key=“”
[network_server.gateway.stats]
create_gateway_on_stats=true
timezone=“”
aggregation_intervals=[“minute”, “hour”, “day”]
[network_server.gateway.backend]
type=“mqtt”
uplink_topic_template="gateway/+/rx"
downlink_topic_template="gateway/{{ .MAC }}/tx"
stats_topic_template="gateway/+/stats"
ack_topic_template="gateway/+/ack"
config_topic_template="gateway/{{ .MAC }}/config"
server="tcp://localhost:1883"
username=""
password=""
qos=0
clean_session=true
client_id=""
ca_cert=""
tls_cert=""
tls_key=""
[network_server.gateway.backend.gcp_pub_sub]
credentials_file=""
project_id=""
uplink_topic_name=""
downlink_topic_name=""
uplink_retention_duration="24h0m0s"
[geolocation_server]
server=“”
ca_cert=“”
tls_cert=“”
tls_key=“”
[join_server.default]
server=“http://localhost:8003”
ca_cert=“”
tls_cert=“”
tls_key=“”
[network_controller]
server=“”
ca_cert=“”
tls_cert=“”
tls_key=“”
Any solution to this, having a similar problem with issuing the linkadr mac command and not showing up in the downlink messages being issued
Hii @tmac01,
have you got any solutions for downlink mac command?
any solution found for this
Any progress?
The Go example and Python example here are just about Enqueue downlink, and I want to know more code details about MAC control like active rate and power adjustment.
hi bro B
do you have any idea?
we want know how to send a mac cmd like linkadrreq to modify end device freqbandmask
Why do you need to do that manually? By LoRaWAN, the MAC commands stop at the NS entity, which is why they don’t appear to the application. If it isn’t supported, then Chirpstack’s design probably follows that principle strictly.
The LinkADRReq channel mask is determined by the channels configured, in Chirpstack. You can also disable default channels. So it does not seem necessary to generate this command on your own?
