Hello
Both devices (MTCAP et MTCDT) have a last firmware (6.0.1)
They were started from scratch. (Factory reset + last firmware version)
The problem is on the jonction between lora_packet_forwarder and chirpstack-mqtt-forwarder
mtcdt chirpstack-mqtt-forwarder[5174]: Handle PULL_DATA error: Expected protocol version: 2, got: 1, remote: 127.0.0.1:59944
Its look like to a incorrecte protocol version betwen this 2 applications
It seems that the 2 devices does not use the same packet_forwarder
head /var/log/lora-pkt-fwd-1.log
*** Basic Packet Forwarder for Lora Gateway ***
Version: 1.4.1
*** Lora concentrator HAL library version info ***
Version: 1.7.0; Options: ftdi sx1301 sx1257 full mtac-lora private;
INFO: Little endian host
INFO: found global configuration file global_conf.json, parsing it
INFO: global_conf.json does contain a JSON object named SX1301_conf, parsing SX1301 parameters
INFO: radio 0 enabled, center frequency 868500000
INFO: radio 1 enabled, center frequency 867500000
INFO: Lora multi-SF channel 0> radio 0, IF -400000 Hz, 125 kHz bw, SF 7 to 12
INFO: Lora multi-SF channel 1> radio 0, IF -200000 Hz, 125 kHz bw, SF 7 to 12
INFO: Lora multi-SF channel 2> radio 0, IF 0 Hz, 125 kHz bw, SF 7 to 12
*** Beacon Packet Forwarder for Lora Gateway ***
Version: 4.0.20
Version: 5.0.13;
INFO: lorawan_public 1, clksrc 0
INFO: LBT is disabled
INFO: antenna_gain 3 dBi
INFO: Default Temperature Compensation
INFO: Configuring TX LUT with 16 indexes
Does anybody encounter the problem ?
Or do you see some tips to solve it ?
Guillaume
The source of the problem seems to be the hw-version
On the MTCDT, it is :
root@mtcdt:/tmp# mts-io-sysfs show lora/hw-version
MTAC-LORA-1.0
then, the init.d link the lora_packet_forwarder to lora-packet-forwarder-usb… and not to the classic one.
And this packet forwarder does not support the protocol 2 needed by chirpstack-mqtt-forwarder
Does somebody encounter this problem ?
Yes, I had the same problem with old usb cards.
And as far as I know, there is no solution except changing the LoRa card, but it costs the price of a new gateway.
OK
Thank you.
I will try to change the LoRa card.
Yes the price is high.
Hopefully, only one gateway to change in my case…
Solved without changing the lora card
Solved by using the chirpstack-gateway-bridge V4
So we don’t use chirpstack-mqtt-forwarder which is not appropriate in our cases.
Do you also receive the stats packets with the USB card?
Yes, by using, the binary “gps_pkt_fwd” delivered by lora-packet-forwarder-usb_1.4.1-r2.0_arm926ejste.ipk , under Index of /vendor/multitech/conduit/
thanks to this post : Gateway statistics not showing - #6 by Bocajim
We just untar it and replace the binary, we don’t try to install it by opkg
ar -x lora-packet-forwarder-usb_1.4.1-r2.0_arm926ejste.ipk
cd /opt/lora
cp basic_pkt_fwd-usb basic_pkt_fwd-usb.bk
rm -rf basic_pkt_fwd-usb
ln -s /var/config/somewhere/gps_pkt_fwd basic_pkt_fwd-usb basic_pkt_fwd-usb
I believe the USB packet-forwarder also doesn’t support the TX_ACK
packet, which is sent by the gateway after enqueuing a downlink. ChirpStack needs this information to know if a downlink was accepted by the gateway or not. If not (because of collision, …) it will stay in the queue.
This feature was added in v3.0.0 of the UDP Packet Forwarder.
I know upgrading the module costs money, but the USB packet-forwarder is really outdated. Support was dropped in v2.2.0 (2015-10-08) of the packet forwarder.
On the other hand, one could clone the packet-forwarder source and backport these protocol features
Or maybe Multitech could provide a custom packet-forwarder with these capabilites.
