Mikrotik KNOT LR8 kit
Hello, I am testing the server with Mikrotik KNOT LR8 kit. The device is connected but it s not forwarding information.
In the documentation it is required to install the chirpstack-bridge, but there is not any information about Mikrotik gateways.
Can anyone help ?
on their website it says
This kit contains a pre-installed UDP packet forwarder to any public or private LoRa® servers.
so find the settings for this and point it to your chirpstack lns ip and udp port default 1700 udp for chirpstack.
i cant find anything in their docs from the website on setting up the packet forwarder, if you do not have anything in the webui to set it up you might have to contact them.
can you help i can’t connect this gateway it says last seen never, how did you configure the files?
