Mikrotik LR8 Gateway
Im trying to connect Mikrotik LR8 Gateway to Chirpstack server but i receve this error in network server and gateway is never connected.
lora@lora-OptiPlex-7010:~$ sudo journalctl -u chirpstack-network-server -f
[sudo] password for lora:
Jan 23 11:36:51 lora-OptiPlex-7010 chirpstack-network-server[4764]: time=“2025-01-23T11:36:51.207313769+02:00” level=info msg=“gateway/mqtt: gateway stats packet received” gateway_id=0000000000000000 stats_id=00000000-0000-0000-0000-000000000000
Jan 23 11:36:51 lora-OptiPlex-7010 chirpstack-network-server[4764]: time=“2025-01-23T11:36:51.20821448+02:00” level=error msg=“gateway: handle gateway stats error” ctx_id=00000000-0000-0000-0000-000000000000 error=“update gateway state error: object does not exist”
Jan 23 11:37:21 lora-OptiPlex-7010 chirpstack-network-server[4764]: time=“2025-01-23T11:37:21.208043748+02:00” level=info msg=“gateway/mqtt: gateway stats packet received” gateway_id=0000000000000000 stats_id=00000000-0000-0000-0000-000000000000
Jan 23 11:37:21 lora-OptiPlex-7010 chirpstack-network-server[4764]: time=“2025-01-23T11:37:21.208921284+02:00” level=error msg=“gateway: handle gateway stats error” ctx_id=00000000-0000-0000-0000-000000000000 error=“update gateway state error: object does not exist”
Jan 23 11:37:51 lora-OptiPlex-7010 chirpstack-network-server[4764]: time=“2025-01-23T11:37:51.208637668+02:00” level=info msg=“gateway/mqtt: gateway stats packet received” gateway_id=0000000000000000 stats_id=00000000-0000-0000-0000-000000000000
Jan 23 11:37:51 lora-OptiPlex-7010 chirpstack-network-server[4764]: time=“2025-01-23T11:37:51.209425018+02:00” level=error msg=“gateway: handle gateway stats error” ctx_id=00000000-0000-0000-0000-000000000000 error=“update gateway state error: object does not exist”
Jan 23 11:38:21 lora-OptiPlex-7010 chirpstack-network-server[4764]: time=“2025-01-23T11:38:21.209208987+02:00” level=info msg=“gateway/mqtt: gateway stats packet received” gateway_id=0000000000000000 stats_id=00000000-0000-0000-0000-000000000000
Jan 23 11:38:21 lora-OptiPlex-7010 chirpstack-network-server[4764]: time=“2025-01-23T11:38:21.210041992+02:00” level=error msg=“gateway: handle gateway stats error” ctx_id=00000000-0000-0000-0000-000000000000 error=“update gateway state error: object does not exist”
Jan 23 11:38:51 lora-OptiPlex-7010 chirpstack-network-server[4764]: time=“2025-01-23T11:38:51.205864848+02:00” level=info msg=“gateway/mqtt: gateway stats packet received” gateway_id=0000000000000000 stats_id=00000000-0000-0000-0000-000000000000
Jan 23 11:38:51 lora-OptiPlex-7010 chirpstack-network-server[4764]: time=“2025-01-23T11:38:51.206626382+02:00” level=error msg=“gateway: handle gateway stats error” ctx_id=00000000-0000-0000-0000-000000000000 error=“update gateway state error: object does not exist”
Did you just start with Chirpstack. If so you really should install V4 instead.
In this case though, I would think this is probably an error from the gateway → gateway-bridge connection. Do you have the gateway-bridge on server? What packet forwarder are you using on the gateway (UDP/Basic Station)?
Yes I’m new to this!
Yes I have already installed new version and fixed some issues in gateway and it’s working now!
Yes I have gateway bridge on server and it’s using UDP.
Thanks a lot!
