Milesight EM300-DI: uplink decoding suddenly stopped in Chirpstack
Problem Description
I’m experiencing an unexpected issue with my Milesight EM300-DI sensor. The uplinks from this device have suddenly stopped being decoded.
Details
  • Device: Milesight EM300-DI sensor
  • Issue: since 10/07/24, uplinks are no longer decoded
Current Status
As shown in the screenshot, the uplinks are being received but not decoded.
Troubleshooting Steps Taken
1. Verified that no changes were made to:
  • Device configuration
  • Chirpstack version
  • Chirpstack configuration
2. Tested manual decoding:
  • Attempted manual decoding of the most recent uplink successfully
 * Payload Decoder
 * Copyright 2024 Milesight IoT
 * @product EM300-DI
// Chirpstack v4
function decodeUplink(input) {
    var decoded = milesightDeviceDecode(input.bytes);
    return { data: decoded };
function milesightDeviceDecode(bytes) {
    var decoded = {};
    for (var i = 0; i < bytes.length; ) {
        var channel_id = bytes[i++];
        var channel_type = bytes[i++];
        // BATTERY
        if (channel_id === 0x01 && channel_type === 0x75) {
            decoded.battery = bytes[i];
            i += 1;
        // TEMPERATURE
        else if (channel_id === 0x03 && channel_type === 0x67) {
            decoded.temperature = readInt16LE(bytes.slice(i, i + 2)) / 10;
            i += 2;
            // decoded.temperature = readInt16LE(bytes.slice(i, i + 2)) / 10 * 1.8 + 32;
            // i +=2;
        // HUMIDITY
        else if (channel_id === 0x04 && channel_type === 0x68) {
            decoded.humidity = bytes[i] / 2;
            i += 1;
        // GPIO
        else if (channel_id === 0x05 && channel_type === 0x00) {
            decoded.gpio = readGPIOStatus(bytes[i]);
            i += 1;
        // PULSE COUNTER
        else if (channel_id === 0x05 && channel_type === 0xc8) {
            decoded.pulse = readUInt32LE(bytes.slice(i, i + 4));
            i += 4;
        // PULSE COUNTER (v1.3+)
        else if (channel_id === 0x05 && channel_type === 0xe1) {
            decoded.water_conv = readUInt16LE(bytes.slice(i, i + 2)) / 10;
            decoded.pulse_conv = readUInt16LE(bytes.slice(i + 2, i + 4)) / 10;
            decoded.water = readFloatLE(bytes.slice(i + 4, i + 8));
            i += 8;
        // GPIO ALARM
        else if (channel_id === 0x85 && channel_type === 0x00) {
            decoded.gpio_alarm = readGPIOAlarm(bytes[i + 1]);
            i += 2;
        // WATER ALARM
        else if (channel_id === 0x85 && channel_type === 0xe1) {
            decoded.water_alarm = readWaterAlarm(bytes[i + 8]);
            i += 9;
        // HISTORICAL DATA
        else if (channel_id === 0x20 && channel_type === 0xce) {
            // maybe not historical raw data
            if (bytes.slice(i).length < 12) break;
            var point = {};
            point.timestamp = readUInt32LE(bytes.slice(i, i + 4));
            point.temperature = readInt16LE(bytes.slice(i + 4, i + 6)) / 10;
            point.humidity = bytes[i + 6] / 2;
            var mode = bytes[i + 7];
            if (mode === 1) {
                point.gpio_type = "gpio";
                point.gpio = bytes[i + 8];
            } else if (mode === 2) {
                point.gpio_type = "pulse";
                point.pulse = readUInt32LE(bytes.slice(i + 9, i + 13));
            decoded.history = decoded.history || [];
            decoded.history.push(point);
            i += 13;
        // HISTORICAL DATA (v2)
        else if (channel_id === 0x21 && channel_type === 0xce) {
            var point = {};
            point.alarm = readAlarm(bytes[i + 7]);
            var mode = bytes[i + 8];
            if (mode === 1) {
                point.gpio = readGPIOStatus(bytes[i + 9]);
                point.water_conv = readUInt16LE(bytes.slice(i + 10, i + 12)) / 10;
                point.pulse_conv = readUInt16LE(bytes.slice(i + 12, i + 14)) / 10;
                point.water = readFloatLE(bytes.slice(i + 14, i + 18));
            i += 18;
        } else {
            break;
    return decoded;
 * bytes to number
function readUInt16LE(bytes) {
    var value = (bytes[1] << 8) + bytes[0];
    return value & 0xffff;
function readInt16LE(bytes) {
    var ref = readUInt16LE(bytes);
    return ref > 0x7fff ? ref - 0x10000 : ref;
function readUInt32LE(bytes) {
    var value = (bytes[3] << 24) + (bytes[2] << 16) + (bytes[1] << 8) + bytes[0];
    return (value & 0xffffffff) >>> 0;
function readFloatLE(bytes) {
    // JavaScript bitwise operators yield a 32 bits integer, not a float.
    // Assume LSB (least significant byte first).
    var bits = (bytes[3] << 24) | (bytes[2] << 16) | (bytes[1] << 8) | bytes[0];
    var sign = bits >>> 31 === 0 ? 1.0 : -1.0;
    var e = (bits >>> 23) & 0xff;
    var m = e === 0 ? (bits & 0x7fffff) << 1 : (bits & 0x7fffff) | 0x800000;
    var f = sign * m * Math.pow(2, e - 150);
    var v = Number(f.toFixed(2));
    return v;
function readGPIOStatus(bytes) {
    // 0: low, 1: high
    switch (bytes) {
        case 0:
            return "low";
        case 1:
            return "high";
        default:
            return "unknown";
function readGPIOAlarm(bytes) {
    // 1: gpio alarm, 0: gpio alarm release
    switch (bytes) {
        case 0:
            return "gpio alarm release";
        case 1:
            return "gpio alarm";
        default:
            return "unknown";
function readWaterAlarm(bytes) {
    // 1: water outage timeout alarm, 2: water outage timeout alarm release, 3: water flow timeout alarm, 4: water flow timeout alarm release
    switch (bytes) {
        case 1:
            return "water outage timeout alarm";
        case 2:
            return "water outage timeout alarm release";
        case 3:
            return "water flow timeout alarm";
        case 4:
            return "water flow timeout alarm release";
        default:
            return "unknown";
function readAlarm(bytes) {
    // 0: none, 1: water outage timeout alarm, 2: water outage timeout alarm release, 3: water flow timeout alarm, 4: water flow timeout alarm release, 5: gpio alarm, 6: gpio alarm release
    switch (bytes) {
        case 0:
            return "none";
        case 1:
        case 2:
        case 3:
        case 4:
        case 5:
        case 6:
        default:
            return "unknown";
// Sample uplink data
const uplinkData = {
    bytes: Buffer.from("0175630367b90004687905e10a000a00002a5347", "hex"),
    fPort: 85
// Function to test the decoder
function testDecoder() {
    console.log("Testing Uplink Decoder");
    console.log("----------------------");
    console.log("Input:");
    console.log(JSON.stringify(uplinkData, null, 2));
    console.log("\nDecoded Output:");
    const decodedData = decodeUplink(uplinkData);
    console.log(JSON.stringify(decodedData, null, 2));
// Run the test
testDecoder();
Questions
  1. What could cause uplinks to stop being decoded without any apparent changes to the system?
  2. Are there any logs or additional diagnostics I should check to identify the root cause?
I appreciate any insights or assistance you can provide in resolving this issue.
Resolved. It was my fault confusing two device types.
Sorry for the noise.
