New to Chirpstack. Setting up Windows Server 2016 with latest downloads.
Error when trying to login using Chrome browser and Admin username.
Record exists in Postgres chirpstack_as DB.
Any help would be great.
Thanks,
Russ…
Session info:
C:\chirpstack\application-server>chirpstack-application-server
time=“2021-08-29T13:19:13.9488927-05:00” level=info msg=“starting ChirpStack Application Server” docs=“https://www.chirpstack.io/” version=3.16.0
time=“2021-08-29T13:19:13.9509018-05:00” level=info msg=“storage: setting up storage package”
time=“2021-08-29T13:19:13.9509018-05:00” level=info msg=“storage: setup metrics”
time=“2021-08-29T13:19:13.9519363-05:00” level=info msg=“storage: setting up Redis client”
time=“2021-08-29T13:19:13.9529176-05:00” level=info msg=“storage: connecting to PostgreSQL database”
time=“2021-08-29T13:19:14.0692926-05:00” level=info msg=“storage: applying PostgreSQL data migrations”
time=“2021-08-29T13:19:14.1194238-05:00” level=info msg=“integration: configuring global integrations”
time=“2021-08-29T13:19:14.1194238-05:00” level=info msg=“integration/mqtt: TLS config is empty”
time=“2021-08-29T13:19:14.120351-05:00” level=info msg=“integration/mqtt: connecting to mqtt broker” server=“tcp://localhost:1883”
time=“2021-08-29T13:19:14.1223554-05:00” level=info msg=“api/as: starting application-server api” bind=“0.0.0.0:8001” ca_cert= tls_cert= tls_key=
time=“2021-08-29T13:19:14.1223554-05:00” level=info msg=“integration/mqtt: connected to mqtt broker”
time=“2021-08-29T13:19:14.123359-05:00” level=info msg=“integration/mqtt: subscribing to tx topic” qos=0 topic=application/+/device/+/command/down
time=“2021-08-29T13:19:14.123359-05:00” level=info msg=“api/external: starting api server” bind=“0.0.0.0:8080” tls-cert= tls-key=
time=“2021-08-29T13:19:14.2237024-05:00” level=info msg=“api/external: registering rest api handler and documentation endpoint” path=/api
time=“2021-08-29T13:19:14.2237024-05:00” level=info msg=“api/js: starting join-server api” bind=“0.0.0.0:8003” ca_cert= tls_cert= tls_key=
time=“2021-08-29T13:19:30.8513218-05:00” level=error msg=“finished unary call with code Unknown” ctx_id=476323bc-512d-4662-a898-9c8f1cf927a2 error=“rpc error: code = Unknown desc = missing destination name username in *storage.User” grpc.code=Unknown grpc.method=Login grpc.service=api.InternalService grpc.start_time=“2021-08-29T13:19:30-05:00” grpc.time_ms=3.06 peer.address="[::1]:55214" span.kind=server system=grpc
time=“2021-08-29T13:19:43.6955884-05:00” level=error msg=“finished unary call with code Unknown” ctx_id=31650a74-33b8-4d81-ab10-1ed75359838a error=“rpc error: code = Unknown desc = missing destination name username in *storage.User” grpc.code=Unknown grpc.method=Login grpc.service=api.InternalService grpc.start_time=“2021-08-29T13:19:43-05:00” grpc.time_ms=0 peer.address="[::1]:55214" span.kind=server system=grpc
time=“2021-08-29T13:25:33.9022924-05:00” level=error msg=“finished unary call with code Unknown” ctx_id=2595aeef-e841-451c-815e-b71759c2ae87 error=“rpc error: code = Unknown desc = missing destination name username in *storage.User” grpc.code=Unknown grpc.method=Login grpc.service=api.InternalService grpc.start_time=“2021-08-29T13:25:33-05:00” grpc.time_ms=1.003 peer.address="[::1]:55214" span.kind=server system=grpc
time=“2021-08-29T13:25:43.0136593-05:00” level=error msg=“finished unary call with code Unknown” ctx_id=92eca956-7b43-42fb-9cd8-bc1037cdeea0 error=“rpc error: code = Unknown desc = missing destination name username in *storage.User” grpc.code=Unknown grpc.method=Login grpc.service=api.InternalService grpc.start_time=“2021-08-29T13:25:43-05:00” grpc.time_ms=0 peer.address="[::1]:55214" span.kind=server system=grpc
